Solve Dirichlet Problem: Find u(x,y) Harmonic on Upper Half-Plane
  • Thread starter Thread starter skrat
skrat
Find function ##u(x,y)## that is harmonic on the upper half-plane ##0<Im(z)##. Note that
##u(x,0)=0##, ##x<0##
##u(x,0)=-1##, ##0<x<1## and
##u(x,0)=1##, ##x>1##.
##u(z)=\frac{1}{2\pi i}\int _{I}\gamma '(s)u(\gamma (s))\frac{\alpha '(\gamma (s))}{\alpha (\gamma (s))}Re(\frac{\alpha (\gamma (s))+\alpha (z)}{\alpha (\gamma (s))-\alpha (z)})ds##
Where ##\alpha ## is holomorphic function that maps ##Im(z)>0## into open unit disk, and ##\gamma (s) ## parameterization of the edge.
For this problem ##\alpha (z)=\frac{1-iz}{1+iz}## and it is also obvious that I will have to make at least 3 integrals.
Let's firstly take a look at ##u(x,0)=0##, ##x<0##:
This tells me that ##u(z)=\frac{1}{2\pi i}\int _{I}\gamma '(s)u(\gamma (s))\frac{\alpha '(\gamma (s))}{\alpha (\gamma (s))}Re(\frac{\alpha (\gamma (s))+\alpha (z)}{\alpha (\gamma (s))-\alpha (z)})ds## will be equal to ##0## for all ##x<0##.
But the question here is: What about ##y## ? None of the conditions tell anything about ##y##. What do I do here?
The same question is for ##u(x,0)=-1##, ##0<x<1##:
Here the integral for ##x## goes from ##0## to ##1##. But again, ##y## can be anything from ##0## to ##\infty ##. ?
I guess my question here is: What should I do with ##y## to get ##u(z)##?
Ok, I found out that my relevant equation in original post was a very stupid equation to begin with. I think it would wiser to use the Poisson integral formula for the upper half plane: ##u(x,y)=\frac{y}{\pi }\int_{-\infty }^{\infty }\frac{u(t,0)}{y^2+(x-t)^2}dt## where I am guessing ##t## stands for some kind of parameterization of real axis? http://www.diss.fu-berlin.de/diss/s...ionid=76E8A9CC9C7EE802A569873649AAF2F7?hosts= page 59.
Anyway, now with that in mind:
##u(x,y)=\int_{-\infty }^{0}...+\int_{0}^{1}...+\int_{1}^{\infty} ## where the first integral is obviously ##0##.
##u(x,y)=-\frac{y}{\pi }\int_{0}^{1}\frac{1}{y^2+(x-t)^2}dt+\frac{y}{\pi }\int_{1}^{\infty }\frac{1}{y^2+(x-t)^2}dt##
##u(x,y)=\frac{y}{\pi }[\frac{1}{y}arctan(\frac{u}{y})\mid _{u=x}^{u=x-1}-\frac{1}{y}arctan(\frac{u}{y})\mid _{u=x-1}^{u=-\infty }]##
and finally
##u(x,y)=\frac{1}{\pi }[2arctan(\frac{x-1}{y})-arctan(\frac{x}{y})+\frac{\pi }{2}]##
This should be a bit better than my first attempt.
