Solve for x in this index notation problem
18 replies · 3K views · last reply
chwala
##2^x##=##x^2##
trial/error method
ok, by direct substitution i know that either ##x=2## or ##x=4##
but i would like to prove this analytically, would it be correct saying,
##xln 2= 2ln x##
##xln_{2}2=2 ln_{2}x##
##x=2 ln_{2}x##
##\frac {1}{2}=\frac { ln_{2}x}{x}##
##ln_{2}x^{1/x}##=##\frac {1}{2}##
→##2^{1/2}##=##x^{1/x}##
→##x=2##
is my thinking correct? and how do we show the solution ##x=4?## analytically
I just saw it on another group, where they simply used trial and error to get ##x=2## and ##x=4##
Math_QED said:
I doubt you can solve this analytically. Of course, you have made two guesses, but the question is: are there more? The answer turns out to be yes: https://www.wolframalpha.com/input/?i=2^x+=+x^2
Where did you find this question?
I have made guesses yes and at the same time I have tried to solve the problem and I wanted a feedback on that approach sir.
If one writes ##x^y=y^x## isn't it obvious by symmetry that ##x=y## is always one of the solutions?
i do not disagree,...true, i just wanted to work from the original problem to realize a solution. It is you to inform me whether my steps make sense or not, i have tried showing that, ...yes by symmetry, we would immediately get the solution to the problem as indicated...
chwala said:
Homework Statement:: ##2^x##=##x^2##
Relevant Equations:: trial/error method
##xln 2= 2ln x##
You've implicitly assumed ##x>0## here.
##x=2 ln_{2}x##
→##x=2##
Looks okay, but it doesn't seem like the work really bought you anything. To get to ##x=2## in the last step, you're essentially using the same logic you used to get the solution to the original form, i.e., if you plug in 2, both sides are obviously equal.
The most insightful approach (to me) would be to plot the two functions and see where they intersect. To get the negative root, you'd have to use numerical methods.
vela said:
You've implicitly assumed ##x>0## here.Looks okay, but it doesn't seem like the work really bought you anything. To get to ##x=2## in the last step, you're essentially using the same logic you used to get the solution to the original form, i.e., if you plug in 2, both sides are obviously equal.
Ok, thanks for your feedback...noted with regards.
Which numerical methods would you suggest for the negative roots...
I like Newton-Raphson.
I know it...I will check it out. Cheers
using the graph we get all the solutions...##x=-0.767##, let me check on how to arrive at this using Newton-raphson method...long since i looked at this numerical methods...cheers
so we need to let ##f(x)= 2^x -x^2## for us to check the roots btwn ##x=-1## and ##x=1## rather than,
##f(x)=x^2-2^x##, or it does not matter?
note that at ##f(-1)= -0.5## and at ##f(1)=1## implying that the roots lie in between.
ok, i am getting, ##f'(x)=2^x ln 2 -2x##
##x_{1}=x_{0}- \frac {f(x_{0})}{f'(x_{0})}##
##x_{1}=-1-\frac{-0.5}{2.3465}##
##x_{1}=-1+0.213=-0.787##
am i on the correct path...
What about the lambert w function?is it a reliable way of solving the same problem...just saw it on YouTube.
I mean... Kind of. But if you asked someone to solve the equation ##xe^x=2## and they told you the answer was W(2), would you consider yourself satisfied? That's the level of satisfaction you'll get using that function. If you ask how to evaluate W, it's going to be the Newton-Rhapsody method or something largely equivalent.
😃😃😃 a bit of humour is good during this hard times...
If you can find peace in ln(2) being a satisfying answer, I would W(2) should be equally satisfactory.
But there's no W button on most people's calculators.
