Solve Polynomial Equations: P(x² - 2x) = [P(x-2)]²
  • Thread starter Thread starter Dinheiro
14 replies · 3K views
Dinheiro
Find all polynomials P(x), such that P(x² - 2x) = [P(x-2)]²
Polynomial equations
Let x = y+2, then
P(y²+2y) = P²(y)
I tried to analyse by derivating
P'(y²+2y)(2y+2) = 2P(y)P'(y)
P'(y²+2y)(y+1) = P'(y)P(y)
I am not sure if I derivated correctly, though
Yet, that's it. Any ideas?
Let x = y+2, then
P(y²+2y) = P²(y)
P'(y^2+2y)(y+1) = P'(y)P(y)
I would consider what ##\deg\big( P(x)\big)## says about ##\deg\big(P'(y²+2y)(y+1)\big)## and ##\deg\big( P'(y)P(y)\big)##. I'm not 100% certain, but I'm guessing you will get a good constraint on ##\deg\big( P(x)\big)## which will make it easier to just brute force the coefficients.
Also, and this is just a pet peeve of mine, the appropriate verb and its tenses are differentiate, differentiating, and differentiated.
Good call, let deg(P(x)) = n, then
2(n-1) + 1 = n(n-1)
n² - 3n +1 = 0??
Did I differentiated correctly?
By the way, not peeve at all, my english is quite rusty and I miss sometimes some english technical terms, thanks for the correction xD
2(n-1) + 1 = n(n-1)
Think again about the right hand side of that equation. (I think the corrected form will be tautology.)
Try some other lines:
- find a value of x for which P can be evaluated (or, at least, for which you can limit the possible values to a small set).
- suppose P has a root, α. What other roots are implied?
- what can you say about a local minimum of P?
Why P(x) = Q(x+c)? Did you mean, if the function were periodic of period c, like P(x) = P(x + c)?
By the way, Could you say if I differentiated correctly at post #3? Shouldn't I get an integer n?
Thanks
The answer in my cousin's book seems to be
[itex](x+1)^{n}[/itex]
I really thought the answer would be a monster Oo
No, not periodic:
P(y²+2y) = P²(y)
Q(y²+2y+c) = Q²(y+c)
Can you spot a value of c that makes that interesting?
You differentiated ok, but wrongly evaluated the highest power that would arise on the right hand side. If you do it correctly, you'll find that the equation doesn't tell you anything.
Oh, I see now, thanks :redface:
Let me retry the problem
c = 1, so that Q(y²+2y+1) = Q[(y+1)²]
and, therefore,
Q[(y+1)²]=Q²[(y+1)]
Great, haruspex!
Now, Let y+1 = z
Q(z²)=Q²(z)
Now, I got stucked, how can I really prove Q(z) = (z+1)^n from it? I can guess the answer, but I couldn't really demonstrate it
and, therefore,
Q[(y+1)²]=Q²[(y+1)]
Great, haruspex!
Now, Let y+1 = z
Q(z²)=Q²(z)
Good progress. Now you're in a better position to try one of my first suggestions. (It might have worked with P(), but it's easier with Q().) Suppose α is a root (not necessarily real). What other roots are implied?
Edit: There's an easier way: just consider the lowest two degree terms in Q, ##a_r x^r + a_s x^s##, say. Equate the lowest two terms of Q(x2) with the lowest two of Q2(x).
Great! Thanks, haruspex!
