Solve Quadratic Equation for Single or Multiple Intersections with the x-axis
  • Thread starter Thread starter undefinable
9 replies · 4K views · last reply
undefinable
Find k such that the graph of y=9x^2 + 3kx + k
A) intersects the x-axis in one point only
B) intersects the x-axis in two points
C) does not intersect the x-axis
D= b^2 − 4ac
y= ax^2+bx+c
quadratic equation
I got A but using the discriminent b^2-4ac= 0 meaning there is one root. but I have no idea how to get B and C. The answer is
B) k < 0 or k >4
C) 0<k<4
[tex]y=9x^{2}+3kx+k[/tex], so a=9, b=3k, c=k, now
A) [tex]D=b^{2}-4ac=0[/tex] so we will have two identical solutions, and the graph will touch the x-axis. Probbably you meant here to touch , because it does not really intersect.
B) D>0
C)D<0
SInce a=9>0 it means that the parabola will be opened upward. So when D<0, it means that the parabola does not intersect the x-axis at all, since the quadratic equation [tex]9x^{2}+3kx+k=0[/tex] does not have real roots, while when D>0, it means that there are two distinct roots of the quadratic equation.
Do u know how to go about it now?
Still don't understand.
For A, by using b^2-4ac= 0 I got the answer that k=0 (which is correct)
For B, I still don't understand how to achieve this answer k < 0 or k >4. How can I work with my equations to conclude that the values of k must be k< 0 or k >4 for y=9x^2 + 3kx + k to intersect two places.
well B)[tex]D=b^{2}-4ac>0 =>(3k)^2-4*(9)*(k)>0=>9k^{2}-36k>0[/tex] , do you know how to solve this quadratic inequality?
One method for doint it is like this
[tex]9k^{2}-36k>0=>k^{2}-4k>0=> k(k-4)>0[/tex] then this is greater then zero if:1) k>0, and k-4>0, or 2) k<0 and k-4<0
another method is to first graph the function [tex]y=9k^{2}-36k[/tex] and see at what intervals the function is positive, that is above x-axis.
No.
b^2-4ac = 9k^2 - 36k.
9k^2 - 36k = 0 is a quadratic equation, and it has two solutions.
You only found one solution (k = 0) - what is the other? :smile:
^ Right, 0 and 4, lol
I'm getting the numbers but I'm not getting the greater than and less than signs.
Referring to [tex]9k^{2}-36k>0=>k^{2}-4k>0=> k(k-4)>0[/tex] I got that but then what I concluded from that is k>0 and K>4. HOw can I end up with K<0 ?
Try graphing the quadratic y = k2 - 4k. We are looking for when y > 0. What values of k give that?
undefinable said:
Right, 0 and 4, lol
Hurrah! :smile:
Stop! … think! … k(k-4)>0 … try a few example for k …
Got it? :smile:
i perfectly well explained it in my post #4, that
[tex]k(k-4)>0[/tex] is possible in two cases
[tex] k>0 \ \ and \ \ k-4>0 \ or \ \ k<0 \ and \ \ k-4<0 [/tex] think about this!
It may be easier to do k(k-4) > 0 graphically - the find the intervals for which the curve is above the k axis. Sketching that should be easy.
