Solve Simple Trig Question: Sin x = √3 * Cos X
  • Thread starter Thread starter kscplay
    Trig
kscplay
-sin x = √3 * cos x
where x is [0,2π]
Would it be wrong to square both sides and then factor?
sin2 x = 3cos2 x
1-cos2 x = 3cos2 x
0= 4cos2 x - 1
0 = (2cos x -1)(2cos x + 1)
Now I solve the factors (2 solutions for each)
Since I've squared both sides, haven't I introduced extra solutions that are not part of the original problem? Will all 4 resulting solutions be correct? Thanks.
Well, when you square root something, you will get a positive and a negative answer, which you already know. Since you defined x as [0,2π], there are no negative numbers in that interval. Therefore, you may disregard the negative answers for this interval, which should leave you with two answers.
hi kscplay! :smile:
kscplay said:
-sin x = √3 * cos x
where x is [0,2π]
yes, since you will also be finding the solutions to sin x = √3 * cos x
the same x can't be a solution to both (unless sinx = 0, of course)
i think the only way to decide which solutions to reject is to actually check each one :wink:​
But the simplest way to solve that equation is to divide both sides by -cos(x):
[tex]\frac{sin(x)}{cos(x)}= tan(x)= -\sqrt{3}[/tex]
