Solve the Juggler Problem: Find Vo for Rod to Make Integer Number of Rotations
  • Thread starter Thread starter miew
The discussion focuses on solving the Juggler Problem, specifically determining the initial vertical velocity (vo) required for a juggler to achieve an integer number of rotations with a uniform rod. Key equations include the linear motion equation V = V0 - gt and the rotational motion equation ω = ω0 + αt. The final derived formula for vo is v0 = gnπ/ω, where n represents the number of rotations and ω is the initial angular velocity. Participants emphasized the independence of linear and rotational motions and the importance of torque considerations in the analysis.
  • Understanding of linear motion equations (e.g., V = V0 - gt)
  • Familiarity with rotational motion concepts (e.g., ω = ω0 + αt)
  • Knowledge of torque and its relation to angular motion
  • Basic calculus for solving motion equations
  • Study the derivation of angular motion equations in physics
  • Learn about the relationship between torque and angular momentum
  • Explore the concept of center of mass in rigid body dynamics
  • Investigate advanced projectile motion problems involving rotation
Physics students, educators, and anyone interested in mechanics, particularly those studying rotational dynamics and projectile motion.
miew
b]1. Homework Statement [/b]
A juggler is juggling a uniform rod one end of which is coated in tar and burning. He is holding the rod by the opposite end and throws it up so that, at the moment of release, it is horizontal, its Center of Mass is traveling vertically up at speed vo and it is rotating with angular velocity wo. To catch it, he wants to arrange that when it returns to his hand it will have made an integer number of complete rotations. What should vo be, if the rod is the have made exactly n rotations when it returns to his hand?
L=rxp
torque=dL/dt
I don't even know how to start...
hi miew! :smile:
(have an omega: ω and try using the X2 icon just above the Reply box :wink:)
ok, the linear motion and the rotational motion are completely independent, so start by writing out the two equations for them (one each), as a function of t …
what are they? :smile:
think this,
lest rod goes up by some distance l(doesn't matter what's l)
you can calc. what time will it take to come to same horizontal level
in that time the rod should make n rotations
find time for 1 rotation using wo
now time of flight = time for n complete rotations
So, for the linear motion:
V=V0-gt
And for the rotational motion:
\omega= \omega 0+\alphat
Cupid.callin what do you mean by lest rod goes up by some distance l?
i meant Let
hi miew! :smile:
(what happened to that ω i gave you? :confused:)
V=V0-gt
ω = ω0 + αt
Yes, that's correct, but you really need equations for s and θ, not ω and α :smile:
(didn't I use omega :/ ? )
So the time to make one rotation is t= 2 \pi / \omega0 right ?
And in that time it goes up a distance x= Vot - \frac{1}{2}gt where t is the one above ?
Am I in the right track ? :)
hi miew! :smile:
(just got up :zzz: …)
(easier to type and to read if you use ω and π instead of the LaTeX versions :wink:)
yup! :biggrin: (gt2, of course) …
except the question says he's a really good juggler, and you have to use nt instead of t :wink:
ok, now find an equation relating v0 and ω0, and then solve for v0 ! :smile:
(I can't find your omegas and pi...:( )
Okay, so this is what I got.
t=2npi/\omega
Vf=v0-gt and since Vf=0, v0=gt
but it goes up and down, so the total time is
t=2vo/g.
And then, v0=gnpi/\omega
Is that right ? :)
hi miew! :smile:
(you could have copied-and-pasted the ω and π i used :wink: … see a fuller list below)
yes that's fine …
but you could have done it slightly quicker by saying that when it returns, v will be minus v0, so v0 - (-v0) = gt :wink:
(alternatively, 0 = v0t - gt2/2 give the same result without having to know that v = -v0)
Oh you are right !:smile:
THank you so much for your help, you were really helpful :smile:
Hi, bringing up this old thread because I was stuck on the same problem for a little bit, though for a different reason. I understand the derivation as it is, but the thing that held me back was accounting for the torque due to gravity. Is the torque on each infinitesimal rod element canceled by the torque on element opposite the center of mass?
hi diligence! :smile:
diligence said:
… the torque due to gravity. Is the torque on each infinitesimal rod element canceled by the torque on element opposite the center of mass?
yes (even for an irregular shape) …
∫ ρ (r - rc.o.m) x g dxdydz
= {∫ ρ (r - rc.o.m) dxdydz} x g
= 0 x g :wink:
Thanks Tim. So I guess it's basically inherent in the definition of center of mass? Yes, that's now obvious in hindsight. Thanks!
10K
