Solve the recurrence relation using iteration
7 replies · 2K views · last reply
cilla
[/B]
Solve the recurrence relation (use iteration).
an = an-1 + 1 + 2n-1
a0 = 0
Then prove the solution by mathematical induction.
a1 = 2
a2 = 5
a3 = 10
a4 = 19
a5 = 36
The solution appears to be an = n + 2n - 1
How are we supposed to get that though? I just guessed and did trial and error. That's really the only/primary way?
Also, what are the properties of this recurrence relation (e.g., linear, homogeneous, etc.)? Why?
Also sorry if this is posted in the wrong section, I didn't know where it belongs if not here.
So how do I prove (or disprove, since I've only tried it out for so many of these) my solution using induction?
Thank you so much.
[itex]a_1 = a_0 + 1 + 2^0 = 1 + (2 - 1)[/itex]
[itex]a_2 = a_1 + 1 + 2^1 = 1 + 2^0 + 1 + 2^1 = 2 + (1 + 2) = 2 + (4 - 1)[/itex]
[itex]a_3 = a_2 + 1 + 2^2 = 2 + (1 + 2) + 1 + 2^2 = 3 + (1 + 2 + 4) = 3 + (8 - 1)[/itex]
etc...
Can you spot any patterns?
cilla said:
[/B]
a0 = 0
a1 = 2
a2 = 5
a3 = 10
a4 = 19
a5 = 36
Thank you so much.
Use the fact that ##a_n - a_1 = (a_n - a_{n-1}) + (a_{n-1} - a_{n-2}) + \cdots + (a_2 - a_1)##, and you have a formula for ##a_k - a_{k-1}##.
etc...
Yeah that's what I did.
So how do I prove my solution by induction?
What's that formula for though?
For proof by induction I need to make ##a_{k+1} = (k+1) + 2^{k+1} -1## right?
Are you claiming that you have never seen the formula for ##\sum_{k=1}^n r^k##? You can look in books or on-line for an answer.
HInt: geometric series.
What does linear mean? What does homogeneous mean? These are basic definitions you should look up for yourself.
There's a bit more to it. There are two parts to a proof by induction. Do you know what they are? If not, you should find out what they are. Apparently, this is something you're already supposed to know.
Yeah. I know. You do the base step, then the induction step. I didn't have the starting form right, was confused about what I was supposed to actually be proving... I was just thinking to prove the k+1 part but what I'm supposed to be proving is that the initial recurrence relation formula given is equal to the one I got. Once I realized that (I know, seems painfully obvious), I got it. Thanks.
