Solve Trig Problem: 0.15kg Mass w/ Wall & Lift @ 65° Angle
  • Thread starter Thread starter Tevion
    Angles Trig
The discussion revolves around a physics problem involving a 0.15kg mass positioned between a vertical wall and a lift inclined at an angle of 65°. The forces acting on the mass include its weight, the normal reaction from the lift, and the normal reaction from the wall. Participants are tasked with analyzing the angles and magnitudes of these forces, as well as exploring a variation of the problem where the angle is expressed in radians.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationships between the forces acting on the mass, including the angles between them. There is an attempt to derive expressions for the normal forces based on the geometry of the situation. Some participants express confusion over the notation and terminology used in the problem, prompting requests for clarification.
The discussion is ongoing, with some participants providing insights into the force diagram and relationships between the forces. There is a mix of attempts to clarify the problem and requests for further assistance, indicating a collaborative exploration of the concepts involved.
Participants note the need to understand the implications of changing the angle from degrees to radians and how this affects the calculations of the normal forces. There is also mention of the importance of clear communication regarding the symbols and terms used in the problem.
Tevion
A mass 0.15kg sits in a corner between a vertical wall and a lift, that makes an angle of 65° with the wall. The only force acting on the mass is its weight (W), its normal reaction (Nr) from the lift and its normal reaction (Nw) from the wall. The mag of the acceleration due to gravity to be g = 10ms^2
1) Show that the angle between the directions of the forces W and Nr, is 155°
2) Draw a force diagram for the forces acting on the mass, giving the sizes of the angles between the forces
3) Draw a corrresponding triangle of forces, giving the sizes of angles
4) Use the triangle of forces to find the magnitudes of the two normal reactions in Newtons
Any help with the above would be most appriciated.
Thanks
You're not likely to get much help without showing some attempt at these problems first.
ok, its not great :( I am really struggling with this one.
Attached is my attempt
Did that help?
got it :D
Good to hear. I was about to jump in with some help, but it looks like it's not needed now.
Well i won't turn down assistance, and advice, so please go on :)
now its a bit trickier and would like some help please.
rather than the angle being 65 degrees, but is x in radians where 0 < x < 1/2pi.
then Nr depend on the value of x.
the Nr from the lift have mag. fr(x) N. Assuming domain of F fr is (0,1/2pi]
1) we need to use the triangle of forces to show that f, fr has rule
[math]fr(x) = \frac{1.5}{sin x}[/math]
2) find the value of fr (1/2pi) and explain this value makes sense in context of model
You've lost me on some of what you wrote.
You have too many symbols there and not enough words explaining what they mean. Some of it I understand from the previous problem.
Nr is the normal force of the mass. What does "mag. fr(x) N" mean? What does F fr mean?
Assuming that the only thing that has changed from the first problem is that the angle the lift makes with the wall is now x radians versus 65 degrees, the force diagram for the mass looks pretty much like the one for the first problem. The mass exerts a force straight down, its weight W. This vector can be decomposed into two normal forces: a horizontal force to the left, perpendicular to the wall, Nw, and a force that is perpendicular to the lift, Nr. The two normal forces Nw and Nr can be added to produce the force acting straight down, W.
Given that the lift makes an angle of x radians with the wall, the force diagram has one vector pointing to the left, and one vector pointing straight down, and one vector that points down and to the right. Vector W is the diagonal of a parallelogram.
Let's say that the angle between W and Nr is y radians. If the lift makes an angle of x rad. with the wall, it must be that x + pi/2 + y = pi, so y = pi - pi/2 - x = pi/2 - x radians.
If you have made a sketch of the situation, it should be fairly straightforward to calculate the magnitudes of the three vectors.
  • · Replies 30 ·
9K
