Solving |3x - 5| > |x + 2| and |x - 3| + |2x - 8| = 5
4 replies · 2K views · last reply
askor
Member warned that homework problems must be posted in the Homework sections
How to solve these two absolute value problems?
1.
##|3x - 5| > |x + 2|##
My attempt:
From what I read in my textbook, the closest properties of absolute value is the one that uses "equal" sign
##|3x - 5| = |x + 2|##
##3x - 5 = x + 2##
##3x -x = 5 + 2##
##2x = 7##
##x = \frac{7}{2}##
##3x - 5 = -(x + 2)##
##3x - 5 = -x - 2##
##3x + x = 5 - 2##
##4x = 3##
##x = \frac{3}{4}##
However, this absolute uses ">" sign. So, how do you solve this one?
2.
I don't understand at all of absolute value problem like above one. Please help me.
Note: this is the absolute value properties from my textbook (please see attached file).
1.
My attempt:
##3x - 5 = x + 2##
##3x -x = 5 + 2##
##2x = 7##
##x = \frac{7}{2}##
##3x - 5 = -x - 2##
##3x + x = 5 - 2##
##4x = 3##
##x = \frac{3}{4}##
2.
Start with the simplest case: what is the solution if both ##2x-5## and ##x+2## are both greater or equal to zero? What condition(s) do you get on ##x## then?
The abs() function is continuous, so as x varies continuously |3x-5|-|x+2| cannot switch between >0 and <0 without passing through =0.
Thus, the solutions you found for the equals case represent the boundaries for the positive and negative ranges. It is just a matter of testing values of x between and beyond those points.
For (2), you have more cases to consider. How many?
Following on from this, I would say the simplest approach is to draw a graph of both functions to see graphically where ##|3x -5|## is greater than ##|x + 2|##.
Perhaps it comes to the same thing, but I look at the points where the individual terms become zero.
In general, we have ##\Sigma a_i|x-b_i|>c##. The ai can be signed.
The function is continuous and consists of straight lines between the points ##x=b_i##. It is not hard to plot the values of the function at those points, and to see what happens as x tends to ±∞.
