Solving 4*ln(3x)=15 for x
  • Thread starter Witcher
7 replies · 3K views · last reply
Witcher
I have this problem that seems to be too easy to be true. I don’t know if i am done and would like to move on to the next problem.
4Ln3x=15
I stopped where it says e^15=3x^4 it seems complete but i am not sure.
  • Handwritten notes on lined paper: x^2 - 4x + 3 = 0 factored as (x - 3)(x - 1) = 0; then 3d. 4 ln 3x = 15, rewritten as ln 3x^4 = 15 and e^15 = 3x^4, with faint 'ln e' written below.
Witcher said:
Homework Statement:: I have this problem that seems to be too easy to be true. I don’t know if i am done and would like to move on to the next problem.
Homework Equations:: 4Ln3x=15
Seems like an odd place to stop. Aren't you trying to solve for x?
Handwritten work on lined paper: 3d. 4 ln 3x = 15, then ln 3x^4 = 15, then e^15 = 3x^4, with the word 'the' partly visible beneath.
In addition to what @OmCheeto said, you have made an error in applying the rule:
##m \cdot \ln(A) =\ln(A^m)##​
Rather than ## \ln(3x^4) ##, you should have ## \ln((3x)^4) ##.
Yea just solving for x but it’s X^4. I may have a few more things in mind that may work.
As already noted, your second line is wrong. Instead of ##\ln 3x^4 = 15##, you should have what @SammyS wrote in his post.
A different approach would be to divide both sides by 4 as your first step, to get ##\ln (3x) = \frac {15} 4##. From there it's only two steps to get the solution.
Are you not clear on what "solve an equation" means?
To solve an equation in x means to find the value or values of x that satisfy the equation. No, writing [itex]3x^4= e^{15}[/itex] has NOT solved the equation (and what you have done is incorrect). You must have an equation of the form "x= something".
Starting from [itex]4ln(3x)= 15[/itex], divide both sides by 4 to get ##\ln(3x)= \frac{15}{4}##. Then take take the exponential of both sides ##3x= e^{\frac{15}{4}}##. Last, divide both sides by 3: ##x= \frac{1}{3}e^{\frac{15}{4}}##.
Another way to approach this problem, and more like what you probably did, is, instead of dividing both sides of the equation, take the "4" inside the logarithm: [tex]ln((3x)^4)= 15[/tex]. Notice that it is both "3" and "x" that are to the 4th power. This is NOT "[itex]3x^4[/itex]" it is [itex](3x)^4= 81x^4[/itex]. So [itex]ln(81x^4)= 15[/itex] and taking the exponential of both sides [itex]81x^4= e^{15}[/itex]. [itex]x^4= \frac{e^{15}}{81}[/itex] and then take the fourth root of both sides: [itex]x= \frac{(e^{15})^{1/4}}{\sqrt[4]{81}}= \frac{e^{15/4}}{3}[/itex] as before.
My crude but practical steps are show here but in pure text.
ln(3x)=15/4
e^(15/4)=3x
x=(e^(15/4))/3
With the approaches above, you are sure covered. Maths& science is fun.
