Solving a constraint on sensor array weights for omnidirectional patterns
5 replies · 2K views · last reply
I have the following equation to solve for the coefficients b:
[itex]\sum\limits_{m,n=0}^N b_m b_n^* (x_{mn}+y_{mn}) e^{ ik (ux_{mn} + vy_{mn}) } = 0[/itex]
which must be satisfied for all u and v in the interval [-1,1]. Here k is a constant, b is a vector of length N with unit norm
[itex]||b||^2=1[/itex],
and x and y are vectors of constants with
[itex]x_{mn}=x_m-x_n \text{ and } y_{mn}=y_m-y_n[/itex].
This equation arises in an analysis of plane waves incident on an array of sensors; the question (not homework) is to find weights on the various sensors such that the weighted element voltages sum to create an omni-directional sensitivity power pattern. I am happy to provide the derivation of how the physical system leads to this equation if it would be helpful.
Arguing from physical intuition, the sole solution appears to me that all [itex]b_m=0[/itex] except for one (call it [itex]b_0[/itex], it doesn't matter which we choose) that has unity modulus, [itex]b_0=e^{i\phi}[/itex]. This works because [itex]x_{00}=y_{00}=0[/itex] and is equivalent physically to turning M-1 sensors off and receiving with just a single active sensor. Choosing the arbitray constant as [itex]\phi=0[/itex] results in
[itex]\mathbf{b}\rm=\array{[1&0&&0&...&0]}^T[/itex]
where, again, the indexing is arbitrary so we can assign the active element to any element in the array.
Can anyone suggest a more rigorous argument?
I see issues with an FFT. First, x and y don't ncessarily have regular spacing, so this expression is not a DFT. We could take a DFT of both sides, but I don't think that simplifies anything.
As for the title of my post--Oops, obviously the equation is nonlinear. I had started with an earlier version of the problem involving the electric field (rather than power) pattern
[itex]\sum\limits_{n=0}^{N-1} b_n e^{ -ik (ux_n + vy_n) } = \alpha e^{i\phi(u,v)}[/itex]
then failed to notice that the title needed to change. Perhaps this linear form is easier to deal with, but it has a constant [itex]\alpha[/itex] and a function [itex]\phi(u,v)[/itex] that are arbitrary, so I wasn't sure what to do with it.
EDIT: corrected upper limit
Well, the linear form is a general problem of the ##A x = b## type where ##x_n = b_n## and ##b = \alpha e^{i\phi(u,v)}## discretely sampled. You could try one of many approaches to linear systems LU or QR or singular value decomposition. Depends of the size of ##N##. How badly do you want a solution?
Paul, these are numerical techniques that won't work when your A is a function and b is unspecified. I'm looking for a general demonstration or proof that the solution is of the form b=[1 0 0 ... 0].
I'm confused. Aren't there many counter examples given ##\phi## is arbitrary? Proof, assume a solution not of this form. Compute the corresponding ##\phi##?
