Solving a system of ODEs with substitution/elimination
3 replies · 3K views · last reply
Lahooty
Use substitution/elimination to find the general solution.
dx/dt = 3x-y+2t^2
dy/dt = 4x-2y-8t^2
I'm practically clueless on how to solve this problem using substitution/elimination, I'm pretty sure the way I'm doing it is completely wrong. If anyone can show me the correct approach or can show an example it would be a tremendous help.
dx/dt = 3x - y +2t^2
dx = (3x -y +2t^2)dt
x = 3xt - yt + 2/3t^3
x(1-3t) = - yt + 2/3t^3
x = (-yt + 2/3t^3)/(1-3t)
I know this is not the correct way but I can't find anything online, so if someone does know what to do please reply.
Thanks
x is a function of t. If you integrate it, you get [itex]\int x(t)\,\mathrm{d}t[/itex], not xt. Similarly for y.
dx/dt = 3x-y+2t^2
dy/dt = 4x-2y-8t^2
We want to eliminate either x or y and its derivatives to get a second order ODE for whichever variable we're left with.
Here it seems easiest to eliminate y, since the first equation tells us that
[tex]y = 3x - \frac{\mathrm{d}x}{\mathrm{d}t} + 2t^2[/tex]
Differentiating this gives
[tex]\frac{\mathrm{d}y}{\mathrm{d}t} = 3\frac{\mathrm{d}x}{\mathrm{d}t} <br /> - \frac{\mathrm{d}^2x}{\mathrm{d}t^2} + 4t[/tex]
You can now substitute these expressions for y and dy/dt into the second equation.
Thanks for the response and help. Alright so here is what I did:
y = 3x- x' + 2t^2;
(3x- x' + 2t^2)' = 4x -2(3x- x' + 2t^2) + 2t^2;
3x' - x'' + 2t^2' = 4x -6x + 2x' -4t^2 + 2t^2
x'' - x' -2x = 2t^2' - 2t^2
r^2 - r - 2 = 0
r = 2, r = -1
I don't know how to proceed from this point on.
y = 3x- x' + 2t^2;
The second equation is [itex]y' = 4x - 2y - 8t^2[/itex], so you should have
[tex] (3x- x' + 2t^2)' = 4x -2(3x- x' + 2t^2) - 8t^2[/tex]
which yields
[tex] 3x' - x'' + 4t = 4x - 6x + 2x' - 4t^2 - 8t^2[/tex]
(because [itex](2t^2)' = 2(2t) = 4t[/itex]) so that
[tex] x'' - x' - 2x = 4t + 12t^2[/tex]
r^2 - r - 2 = 0
r = 2, r = -1
You need to find a solution of
and add to it the general solution of
[tex] x'' - x' - 2x = 0[/tex]
The second part you should know. For the first part, the form of the right hand side suggests taking [itex]f(t) = at^2 + bt + c[/itex] with constants a, b and c, which you should choose so that [itex]f'' - f' - 2f = 4t + 12t^2[/itex].
That gives you [itex]x(t)[/itex], and you can then find [itex]y(t)[/itex] from [itex]y = 3x- x' + 2t^2[/itex].
