Solving an Initial Value Problem for x(t=ln2): Step-by-Step Solution
4 replies · 2K views
Mentor
Solve the initial value problem:
##\frac{dx}{dt} = x(2-x)##, ##x(0) = 1##
for ##x(t=ln2)##.
I moved the right side to the left and multiplied both sides by dt to get:
##\frac{dx}{x(2-x)} = dt##
Integrating gave me:
##\frac{ln|x|}{2} - \frac{ln|x-2|}{2} = t+C##
Then:
##ln|x| - ln|x-2| = 2t + 2C##
##ln|\frac{x}{x-2}| = 2t + 2C##
##\frac{x}{x-2} = e^{2t}e^{2c}##
##\frac{1}{1-\frac{2}{x}} = Ke^{2t}##
Manipulating for a while, I end up with:
##x=\frac{2}{Ke^{2t}}##
Since ##x(0) = 1##, I set the left side to 1 and solve for K, winding up with ##k=3##.
However, when trying to solve for ##x(ln2)## I end up with ##\frac{2}{11}##, which isn't one of my possible answers.
Does my process look even remotely correct?
for ##x(t=ln2)##.
Then:
So you could say ##\frac x {x-2} = Ke^{2t}## Put ##t=0,~x=1## there to get ##\frac x {x-2} = -e^{2t}##. Now put ##t=\ln 2## in that, then solve for ##x##. See if that fixes it.
For ##t## near 0 you have ##x## near 1, and so ##x/(x-2) = e^{2C} e^{2t}## is impossible unless you let ##C## be a complex number. However, ##\ln(|x|/|x-2|) = \ln(x/(2-x))##, and so having ##x/(2-x) = e^{2C} e^{2t}## is OK. Of course, when you re-wrote ##e^{2C}## as ##K## and then forgot the origin of ##K##, you were then able to have a valid formula!
@Drakkith: Ray is quite correct and I didn't notice you had been sloppy with the absolute value signs. A better way for you to have written it would be like this:$$
ln\left | \frac{x}{x-2}\right | = 2t + 2C$$ $$
\left|\frac{x}{x-2}\right | =e^{2t + 2C}=e^{2C}e^{2t}$$ $$
\frac{x}{x-2} =\pm e^{2C}e^{2t} = Ke^{2t}$$
Yes, that seemed to work. I got x=8/5, which is one of the possible answers. Thanks guys!
