Solving Biot-Savart Law for a Ring of Charge
The discussion revolves around applying the Biot-Savart Law to determine the magnetic field generated by a ring of charge. The original poster describes a scenario involving a ring of charge located in the positive Y-Z plane with a specified current direction.
  • Participants discuss the clarity of the problem description, questioning the definitions of the 'z plane' and the orientation of the ring. There are inquiries about the variables used in the calculations, particularly the meaning of 'w' and the coordinates of the infinitesimal segment of the ring.
Some participants have provided clarifications regarding the definitions and variables involved, while others have pointed out potential inconsistencies in the original poster's expressions. There is ongoing exploration of the mathematical setup and the implications of the defined variables.
There are mentions of corrections made to the expressions used in the calculations, and participants are actively engaging with the mathematical details to ensure accuracy. The discussion reflects a collaborative effort to refine the understanding of the problem without reaching a definitive conclusion.
Maxwellkid
This is a simple problem if you work with only magnitude and consider the symmetry of a ring. However, I am taking a detailed approach, and I am not getting the correct answer. Could you please look over my math?
a evenly distributed ring of charge on the positive Y-Z plane has a current, I, flowing counterclockwise or flowing from positive Z direction on top and -Z direction on bottom of ring. Figure out the magnetic field along the X axis of this ring of charge from the center of the ring.
d \vec{B} = \frac {\mu_{o} I}{4\pi} \frac {d\vec{l} \times \hat{r}}{r^2}
below are pictures of the ring of charge. left picture is the sideway view with theta being constant. right picture is the frontal view with phi.
d\vec{l} = <0 , dl cos\phi , dl sin\phi>
\hat{r} = <cos\theta , -w/r sin\phi , w/r cos\phi>
{d\vec{l} \times \hat{r} = \frac{w}{r} cos^2\phi dl \cdot \hat{i} + \frac{w}{r} sin^2\phi dl \cdot \hat{i} + cos\theta sin\phi dl \cdot \hat{j} - cos\theta cos\phi dl \cdot \hat{k}
\frac {d\vec{l} \times \hat{r}}{r^2} =\frac{w}{r^3} 1 dl \cdot \hat{i} +\frac{1}{r^2} cos\theta sin\phi dl \cdot \hat{j} - \frac{1}{r^2} cos\theta cos\phi dl \cdot \hat{k}
dl = w d\phi
\frac {d\vec{l} \times \hat{r}}{r^2} = \frac{w^2}{r^3} 1 d\phi \cdot \hat{i} +\frac{w}{r^2} cos\theta sin\phi d\phi \cdot \hat{j} - \frac{w}{r^2} cos\theta cos\phi d\phi \cdot \hat{k}
ARE ALL MY STEPS CORRECT SO FAR?
Maxwellkid said:
a evenly distributed ring of charge on the positive Z plane has a current, I, flowing counterclockwise or flowing from positive Z direction on top and -Z direction on bottom of ring. Figure out the magnetic field along the X axis of this ring of charge from the center of the ring.
This problem description is not at all clear to me. For starters, what is 'the z plane'? There is such a thing as a z axis, but not a z plane. Do you mean the plane defined by the equation z=0 (AKA the x-y plane)? Or do you mean the y-z plane (x=0) as your pictures would leave me to believe? Or perhaps you mean something else entirely?
Also, the 'top' and 'bottom' of the ring are not well defined. Which direction is up, and which direction is down?
I also see the variable w in your calculations, but no explanation as to what it represents.
z plane refers to the z-y plane. w is the radius of the ring of charge. positive z direction current on top of ring and negative z direction current on bottom of ring (counterclockwise current flow)
Okay, and by 'top' you mean the point (0,w,0)?
Maxwellkid said:
d\vec{l} = <-dl sin\phi , dl cos \phi , 0>
d\vec{l} is an infinitesimal piece of the ring, right? If the ring is entirely in the y-z plane, why does your expression have a non-zero x-coordinate?
Are you sure about the sign of the z-coordinate?
Also, I'm not sure why you would bother introducing a new variable \theta here...why not just work with the variables given ion the problem statement x and w?
\vec{r}=<x,-w\sin\phi,-w\cos\phi>
\implies r=\sqrt{x^2+w^2}
\implies\hat{r}=<\frac{x}{\sqrt{x^2+w^2}},\frac{-w\sin\phi}{\sqrt{x^2+w^2}},\frac{-w\cos\phi}{\sqrt{x^2+w^2}}>
i think you're right
gabbagabbahey said:
This doesn't look like a unit vector to me, its magnitude does not equal 1.
To properly find \hat{r}, Start by finding an expression for \vec{r}, and then divide by its magnitude.
it is a unit vector. try taking the absolute value of it...it comes out to 1
i've made the dl correction in the original post. THANKS. however, the math still comes out to be a bit off...i'm off by a half.
Yes, I realized after I posted that \cos^2\theta+\frac{w^2}{r^2}=1 from looking at your picture.
okay...it's been corrected...i'll check back in a couple of hours...need to be away from computer
Hmmm... looking at your picture it seems that you have defined \phi such that z=w\cos\phi, but looking at you calculations it seems as though you are using z=-w\cos\phi...which is it?
i got it...came out correctly...
thank you!
  • · Replies 25 ·
  • · Replies 26 ·
