Help with depreciation, asymptotes, normal lines, and average rate of change
  • Thread starter Thread starter jai6638
    Car
35 replies · 5K views
How would you find the complex zeros or radical in this case ( if there were not integer roots ) ? would i have more information if i had to find only complex zeroes?
Also, there was a questoin in a sample test where it said " Explain how you would find non-real roots in an equation using your calculuator".. Would I use the table and find it since the graph won't display complex roots?
I'm no specialist with (graphical) calculators but finding roots (whether real or complex) is always possible using formula until the degree of 4.
Well-known is the one for quadratic equations, using [tex]\frac{{ - b \pm \sqrt {b^2 - 4ac} }}{{2a}}[/tex] where you get complex solutions if [itex]{b^2 - 4ac}[/itex] is negative.
Find two triangles for which A=36 degrees , a= 16 and C=17
So do I first find all the angles and sides for the first triangle? What do I do next? Divide the triangle into two and then find the 2 angles of the divided triangle?
If you know A, a and c, you can use the law of sines:
[tex]\frac{{\sin A}}{a} = \frac{{\sin B}}{b} = \frac{{\sin C}}{c}[/tex]
