Solving: cos(k+x) + cos(k-x) = c
  • Thread starter Thread starter bobie
15 replies · 3K views
bobie
Hi, (this is not homework)
is it possible to solve an equation like this:
cos( 30° + x) +3 cos (30° - x) [0] = √13 ?
I already know x = 16°.1
do you know how to find it?
Thanks
I guess the 0 after the second cos is a typo?
It is possible, you can simplify the equation to A*cos(x) = √13 with the right A, afterwards you can solve for all x (there is more than one solution).
Yes it is a typo (= 0)
Thanks,
how do I choose the right A = 3.7527368 ?, and how do I choose the right solution among the many solutions?
cos30cosx -sin30*sinx + 3*(cos30cosx+sin30sinx) = √13 ?
That 3 is new... then you'll need an additional phase in the cosine (or use both sine and cosine).
Anyway, you can use the trigonometric identities to simplify the problem. And you can use a computer to check your work.
I thought there might be a simple way, just out of interest.
I do not want to use a computer. Probably it is a complex procedure
Thanks for your help
Where did that 3 in bold come from?
The issue with your problem is that [itex]\sqrt{13}>2[/itex] and [itex]\cos{x}\leq 1[/itex] for all real x values, so a sum of two cosines couldn't possibly be more than 2. Your answer would be imaginary.
Look at the original post. It now reads (emphasis mine) ##\cos(30^{\circ}+x)+\mathbf{3}\cos(30^{\circ}-x) = \surd 13##, instead of the original ##\cos(30^{\circ}+x)+\cos(30^{\circ}-x) = \surd 13##.
That factor of three makes a huge difference. The original problem did not have a solution in the reals. Add that factor of three in and real solutions do exist.bobie, when you make a mistake in formulating the question, common courtesy demands that you tell us about the mistake. There's no problem making a mistake and letting us know you made a mistake, at least if if you do so early enough. We all make mistakes, after all. There's a big problem with silently changing the formulation and not telling us about the change.
Correct. The left-hand side can be simplified in two ways. One is to collect terms, the other is to replace cos(30°) and sin(30°) with their numeric values. What does that leave you with?
I am awfully sorry I dropped and corrected 3 in the OP .
I found
3.4641 cosx + sinx =√13
That's approximately correct. You'll be much better off if you express that symbolically. Use ##\frac{\surd 3}2## instead of 0.8660254 as the cosine of 30°. This will make it possible to come up with a nice expression for your x.
2√3 cosx + sinx = √13, √12 cosx + sinx =√13
cos x = √13/12 - sinx /√12
sinx = √13 - √12 cosx
then
sinx =√1-cosx2, or is there a better way?
Yes, there's a better way. Start with 2√3 cosx + sinx = √13. Divide both sides by cos(x) and then square both sides. On the right hand side you'll have 13/cos2(x). What's another way to write this? (What's 1/cos(x)?) What trigonometric identity can you apply here?
Hint: Eventually you should get a very simple expression for the tangent of x.
tanx + √12= √13 secx
tanx2 + 2√12 tanx= 13 secx2 -12
2√12 tanx = 13 secx2- tanx2 - 12
tanx = (13 secx2- tanx2 - 12) /√48
