Solving e^(0.1x) = x without context
  • Thread starter Thread starter KStolen
6 replies · 8K views
KStolen
Sorry, I'm not sure what is considered precalculus and what isn't, so hopefully this is in the right section.
[tex]e^{0.1x} = x[/tex]
[tex](1.105170918)^{x} = x[/tex]
Unfortunately there is no context to the question, so I have no idea what approach should be taken. Can somebody explain what should be done?
There is no analytic solution in terms of familiar mathematical functions, but there is a solution in terms of the Lambert W function. See
http://en.wikipedia.org/wiki/Lambert_W_function
Transform the equation to
[tex](-.1 x) e^{-.1 x} = -.1[/tex]
then
[tex]-.1 x = W(-.1)[/tex]
so
[tex]x = -10 W(-.1) \approx 1.11833[/tex]
[edit]Beaten to the punch![/edit]
There are two solutions, not one:
[tex]x=-10W(-.1) = 1.11833...[/tex]
[tex]x=-10W_{-1}(-.1)=35.7715...[/tex]
You can see that if you graph the two.
I see no indication anywhere where only real values were requested and therefore there are actually an infinite number of solutions since the W function is infinitely-valued. For example, [itex]44.491 - 73.0706 i[/itex] is an approximation to one of the complex values. Plot the real and imaginary components of the function and you'll see what I mean. :)
But more importantly, does Stolen know how to arrive at that expression? Just divide by [itex]e^{ax}[/itex] then multiply by -a and get:
[itex]-a=-axe^{-ax}[/itex]
which is now in a form that the W function can be taken on both sides (see reference);
Well I can see how to get [tex]W(-0.1)[/tex] by approximating with Newton's method:
[tex]w_{n+1} = w_{n} - \frac{w_{n}e^{w_{n}}-(-0.1)}{e^{w_{n}} + w_{n}e^{w_{n}}}[/tex] picking any number for [tex]w_{0}[/tex]
How do I know that [tex]W_{-1}(-0.1)[/tex] exists if I don't graph it, as Char.Limit says? And how do I approximate [tex]W_{-1}(-0.1)[/tex]?
Use a fixed point iterator. You have [itex]x=e^{0.1x}[/itex], which is of exactly the right form needed for fixed point iteration, [itex]x=f(x)[/tex]. The only concern is stability, and for that you must have [itex]|f'(x_0)| < 1[/itex] and [itex]|f'(x_f)| < 1[/itex]. Here, <i>x</i><sub>0</sub> is the initial guess and <i>x<sub>f</sub></i> is the final solution.[/itex]
