Solving for a factor in a large sum
  • Level: Undergrad
  • Thread starter Thread starter IsomaDan
    Sum
6 replies · 2K views · last reply
IsomaDan
Dear everyone.
First of all Merry Xmas, when everybody gets to that.
I have a problem solving for a factor within a sum.
My formula looks as follows:
T = Æ© It * A0t
The sum runs from t=1 to N, and the aim is to solve for A0, but all my calculations end up extremely messy.
All the best,
Dan
Mathematics news on Phys.org
Thanks for the reponse.
That is the t'th observation of I. They have no well-defined relation to t. In other words; just a bunch of numbers.
In that case, your equation seems to be a general polynomial of order N. I guess N is probably fairly large (as in... not 2 or 3). You will need to use some numerical method to find roots of the function f(A0) = Æ© It * A0t - T.
I suggest Newton's method, it should be convenient to implement, because you can easily compute the derivative of the function analytically.
Actually it is not that large (N, that is), it is just that it varies a lot from case to case and hence I have written it as a sum.
Thanks so much for the response. I will try to see if it gets me any further!
And just to be clear. The A_0 has t as their exponent. It is not a subscript!
If N is equal to 3 or 4, the polynomial is still solvable by analytic methods, but in general it is easier to use a numerical technique like Newton's Method (which is very easy to program if you choose to do that).
The N = 3 case isn't this bad, but consider the solutions for N = 4:
http://upload.wikimedia.org/wikipedia/commons/9/99/Quartic_Formula.svg
Of course, if you know ##a## is a solution to the polynomial, you can long divide by ##(x-a)## to reduce the degree by 1.
