"Solving for $f(2002)$ in $f(f(x)+f(y))=x+y$
  • Context: MHB
  • Thread starter Thread starter Albert1
The discussion revolves around finding the value of the function $f(2002)$ given the functional equation $f(f(x)+f(y))=x+y$ for all natural numbers $x$ and $y$. Participants explore various assumptions and properties of the function, including linearity and specific values.
  • Some participants propose that if $f$ is linear, then $f(f(x) + f(y))$ could be expressed as $f(x + y)$, leading to the conclusion that $f(2002) = 2002$.
  • Others question the legality of assuming linearity and whether it is valid to conclude $f(2002) = 2002$ based on the functional equation.
  • A participant suggests proving that $f(1) = 1$ as a specific case to support their reasoning.
  • There is a repeated emphasis on the need for assumptions about the function's behavior, particularly regarding its mapping from natural numbers to natural numbers.
Participants express differing views on the assumptions necessary to derive $f(2002) = 2002$. There is no consensus on whether the assumptions about linearity are valid or if they lead to the correct conclusion.
Limitations include the dependence on the assumptions of linearity and the specific behavior of the function $f$. The discussion does not resolve whether these assumptions are justified or if alternative forms of $f$ could satisfy the original equation.
Albert1
A function $f$, defined as $f(f(x)+f(y))=x+y,$ for all $x,y\in N$ find $f(2002)$
Mathematics news on Phys.org
Any hints for a dummy like me :(
My not-so-rigorous solution :o :
Let us assume that $f$ is linear, that is:
$$f(x+y)=f(x)+f(y)\tag{1}$$
$$f(ax)=a\cdot f(x)\implies f(x)=kx\tag{2}$$
Using (1), our functional equation becomes:
$$f(f(x))+f(f(y))=x+y$$
Now, let $y=x$, and the functional equation becomes:
$$f(f(x))=x$$
Using the implication from (2), we find:
$$f(kx)=x$$
$$k^2x=x$$
$$k=\pm1$$
Hence:
$$f(x)=\pm x\implies f(2002)=\pm2002$$
$$f(f(x))=x$$
$$f(kx)=x$$
$$k^2x=x$$
$$k=\pm1$$
Hence:
the answer is :
$f(2002)=2002$
hint:
prove for all $k\in N,f(k)=k$
You do see that $f(x)=-x$ also satisfies the functional equation?
note the defnition of a function
$f(x)=\pm x, x\in N$ is not a function
for example :$f(f(1)+f(1))=1+1=2=f(2)$
how can it be possible $f(1)=1,also\,\, f(1)=-1$
I am saying to consider them as separate cases, both functions $f(x)=x$ and $f(x)=-x$ satisfy the given functional equation (which I probably should not have condensed as I did). However, this means there are (at least) 2 possible values for $$f(2002)$$. :D
Erm... if we consider the $f(x)=-x$, we have that $f(f(x)+f(y)) = f(-x-y)$, which is undefined, since $-x-y \notin \mathbb N$. :eek:
From the problem statement it's not immediately clear if that's acceptable, or if we do require that it is defined.
If we don't require that it's defined, then any function with $f(x) < 0$ for all $x\in\mathbb N$ is a solution, since effectively there are no constraints at all.
And if we do require it to be defined, that rules out the solution $f(x)=-x$...
I see it now...I was thinking only $x$ and $y$ need be natural numbers, but so does $-(x+y)$ if we consider $f(x)=-x$. I'll go stand in the corner now. (Sadface)
To be super-nitpicky, in the original post $f$ is not required to be a function $\Bbb N \to \Bbb N$ though, so it might as well have taken negative integer arguments (the functional equation is required to be satisfied only for natural number arguments though). But probably you're right that that's what is meant.
So we need to make the following assumptions (in the case that the answer is indeed $f(2002) = 2002$);
$f : \mathbb{N} \rightarrow \mathbb{N}$,
Linearity : $f(x + y) = f(x) + f(y)$, $f(ax) = af(x)$
and of course, $x, y \in \mathbb{N}$ as stated.
Is this correct?
Can we then just say that.. $f(f(x) + f(y)) = f(x + y) = x + y$, then clearly, $f(2002) = 2002$? Or am i doing something illegal.
This is the case that f(x) = x, f(y) = y.
Is this correct?
may be I should make it clear :
$f:\ N \rightarrow\,\, N,\,\, and \,\,f(f(x)+f(y))=x+y, \,\, (for \,\,all \,\, x,y\in N)\,\,.find\,\, f(2002)$
now here is the question , I didn't say $f$ is linear .
this is a "not-so-rigorous solution "
A little more rigorous.
Let's assume that $0\in N$, then we have:
$f(f(0)+f(0))=0+0 \quad\Rightarrow\quad f(2f(0))=0 \quad\Rightarrow\quad f(0+0)=f(f(2f(0))+f(2f(0)))=2f(0) + 2f(0) \quad\Rightarrow\quad f(0)=0$
Lemma
Let $a=f(1)$. Then for all $k\in N$: $f(k)=ka$ and $f(ka)=k$.
Proof
By induction.
Base case: $f(0)=0=0a$ and $f(0a)=f(0)=0$.
Induction step: we assume the lemma holds up to $k$, then it follows that:
$f(k+1)=f(f(ka)+f(a))=ka+a=(k+1)a$ and $f((k+1)a)=f(ka+a)=f(f(k)+f(1))=k+1$.
Qed.
Since we have $f(k)=ka$ it follows that $f$ is linear, and as MarkFL has already shown, that implies:
$k=f(ka)=ka^2 \quad\Rightarrow\quad a=1$.
Therefore $f(2002)=2002$.
Given linearity, shouldn't that be $f(f(x) + f(y)) = f(f(x + y)) = x + y$, or more generally $f(f(x))=x$? (Wondering)
Lemma
Proof
By induction.
Qed.
Why assume that $0\in N ?$
Never mind if $f$ is linear or not.(only use the given condition)
key point is how to prove $f(1)=1 $
you can not say $f(f(1)+f(0))=1+0=1$,since $0 \notin N$
we should prove $f(1)=1,f(2)=2,f(3)=3,----$and then use inductive method
suppose $f(1)=1$ (here you must prove)
$f(f(1)+f(1))=f(2f(1))=f(2)=1+1=2$
$f(f(1)+f(2))=f(1+2)=f(3)=1+2=3$
$f(1)=1, why\,?$
$f(1)=1, why\,?$
It's ambiguous whether $0\in N$ or not. See e.g. wiki.
The problem statement didn't mention it, so I took the liberty to include $0$, since the proof becomes a bit simpler if we assume $0$ is included. ;)
And no, I'm not using that $f$ is linear - I'm proving it as a spin-off.
Prove:$f(1)=1$
suppoe $f(1)=c$
$f(2c)=f(c+c)=f(f(1)+f(1))=1+1=2----(1)$
we must prove $c=1$
if $c=1+a>1, \,\,and\,\, f(a)=b\,\, (a,b\in N)$
$f(2b)=f(b+b)=f(f(a)+f(a))=2a$
$f(2c)=f(2+2a)=f(f(2c)+f(2b))=2c+2b>2---(2)$
from $(1)(2)\,\,c>1$ is impossible
$\therefore c=1,\rightarrow f(1)=1$
now use inductive method
let $f(k)=k$
we have $f(k+1)=f(f(k)+f(1))=k+1$
the proof is done
therefore $f(2002)=2002$
