Solving for gravitational constant from escape velocity formula
6 replies · 3K views · last reply
Edwin1974
Hi.
I would like to know if it is possible to "reverse engineer" the formula below to find (G) if Ve, M and r are all known values.
Ve = sqrt{2GM/r}
Ve would be escape velocity, G would be gravitational constant, M would be mass of planet and r would be radius of planet.
I hope I am explaining myself correctly here.
In other words how would I go about reversing the formula Ve = sqrt(2GM/r) so that is begins with G =
Kind Regards
Edwin.
Hello, and welcome to MHB, Edwin! (Wave)
We are given:
$$V_e=\sqrt{\frac{2GM}{r}}$$
What do we get if we square both sides of the equation?
Hi Mark.
Thank you for replying to my question. If I square the one side of the equation I get 125075572.2797 and I arrive at the same answer if I square the other side.
I should just let you know that my math skill is equal to about 10 to the power of minus 11 ok, so really struggling with this one. I am not really sure what you are trying to show me with squaring both sides of the equation, I see that by doing that I arrive at the same answer but don't know how that knowledge is used to reverse calculate Ve = sqrt{2GM/r} so that the equation can begin with G = . I hope I am making sense, if not please let me know.
Kind Regards
Edwin.
After you square both sides, make sure to multiply by $r$ to get rid of the fraction.
Once you do that, you should have a simple equation to solve using multiplication and division.
What are you getting as a solution without plugging in numbers for each unknown?
$$V_e=\left(\frac{2GM}{r}\right)^{1/2}$$
$$V^2_e=\left(\frac{2GM}{r}\right)^{1/2}\cdot\left(\frac{2GM}{r}\right)^{1/2}=\left(\frac{2GM}{r}\right)^{1/2+1/2}=\left(\frac{2GM}{r}\right)^1=\frac{2GM}{r}$$
$$V^2_e\cdot\frac{r}{2M}=\frac{2GM}{r}\cdot\frac{r}{2M}$$
Can you continue?
Thank you for all your help here guys.
G = (Ve^{2})/2M
Kind Regards
Edwin
G = (Ve^{2})/2M
Kind Regards
Edwin
It's actually:
$$G=\frac{rV_e^2}{2M}$$
