Solving Heat Equation w/ Neumann BCs Different Domain
The discussion focuses on solving the heat equation \(\frac{\partial u}{\partial t} = \frac{\partial^2 u}{\partial x^2}\) with initial condition \(u(x,0) = a \exp(-\frac{x^2}{2c^2})\) and Neumann boundary conditions \(\frac{\partial u}{\partial x}(-1,t) = \frac{\partial u}{\partial x}(1,t) = 0\). The user initially attempts a separation of variables approach, leading to the equations \(f''(x) + \lambda f(x) = 0\) and conditions involving \(A\) and \(B\). A suggestion to utilize a Laplace transform for the time variable is made, indicating that a transform method may yield a more effective solution than separation of variables.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with Neumann boundary conditions
  • Knowledge of separation of variables technique
  • Basic concepts of Laplace transforms
  • Research the application of Laplace transforms in solving PDEs
  • Study the implications of Neumann boundary conditions in heat equations
  • Explore advanced techniques in separation of variables for non-standard domains
  • Investigate the uniqueness and existence of solutions for heat equations
Mathematicians, physicists, and engineers working with heat transfer problems, particularly those dealing with partial differential equations and boundary value problems.
maxtor101
Hi guys!
I'm to find the solution to
Subject to an initial condition
u(x,0) = u_0(x) = a \exp(- \frac{x^2}{2c^2})
And Neumann boundary conditions
\frac{\partial u}{\partial x} (-1,t) = \frac{\partial u}{\partial x} (1,t) = 0
I can usually do this no problem assuming the domain is for instance [0,L], but I get stuck with this one :
Using separation of variables :
u(x,t) = f(x)g(t)
This yields:
\frac{1}{g} \frac{dg}{dt} = \frac{1}{f} \frac{d^2f}{dx^2} = -\lambda
Spatial Part:
\frac{d^2f}{dx^2} + \lambda f = 0
Therefore :
f(x) = A \cos(\sqrt{\lambda} x) + B \sin(\sqrt{\lambda} x)
And since I'm considering Neumann Boundary conditions I get the derivative of this
f \prime (x) = -A \sqrt{\lambda}\sin(\sqrt{\lambda} x) + B \sqrt{\lambda} \cos(\sqrt{\lambda} x)
So, f \prime (-1) = 0
This gives:
A \sin(\sqrt{\lambda}) + B \cos(\sqrt{\lambda}) = 0
And for f \prime (1) = 0
I get :
-A \sin(\sqrt{\lambda}) + B \cos(\sqrt{\lambda}) = 0
So from these two equations I can conclude that:
Firstly by just adding the two equations
So either B = 0 or \cos(\sqrt{\lambda}) = 0
Now substituting B \cos(\sqrt{\lambda}) = 0 back into A \sin(\sqrt{\lambda}) + B \cos(\sqrt{\lambda}) = 0
I also get
A \sin(\sqrt{\lambda}) = 0
So either A = 0 or \sin(\sqrt{\lambda}) = 0
Obviously \sin(\sqrt{\lambda}) and \cos(\sqrt{\lambda}) can't both equal zero, so how do I approach this...
Apologies if this is a stupid question..
Any help would be greatly appreciated
Max
Have you tried a transform method? I might be tempted to try a Laplace transform on the t variable. I think that this problem requires a transform solution rather than a separation of variable solution.
sin(\sqrt{\lambda}) and cos(\sqrt{\lambda}) don't both have to be 0: one of A and B can be 0 and still give you a non-trivial solution.
Ah ok I see! Thanks for your help.
So I can choose for example in case 1: A=0 , B=B . case2: B=0 , A=A
  • · Replies 28 ·
