Solving log₃(3x-5) + log₁/₃(12) = 1-x
  • Thread starter Thread starter songoku
    Logarithm
17 replies · 4K views
songoku
log3(3x-5) + log(1/3) 12 = 1 - x
logarithm
exponential
The best I can get is:
[tex]\frac{3x-5}{12}=3^{1-x}[/tex]
Can this be solved??
Thanks
You have two different bases and what you did to get your equation in part three ignored the two different bases. Use the change-of-base formula.
[itex]\[<br /> \log _b x = \frac{{\log _k x}}{{\log _k b}}<br /> \][/itex]
[itex]\[<br /> \log _{{\raise0.5ex\hbox{$\scriptstyle 1$}<br /> \kern-0.1em/\kern-0.15em<br /> \lower0.25ex\hbox{$\scriptstyle 3$}}} 12 = \frac{{\log _3 12}}{{\log _3 \left( {{\raise0.5ex\hbox{$\scriptstyle 1$}<br /> \kern-0.1em/\kern-0.15em<br /> \lower0.25ex\hbox{$\scriptstyle 3$}}} \right)}}<br /> \][/itex]
Please excuse the slightly bad formatting result in lefthand member of last equation. "Logarithm to the base one-third of twelve..."
This is what I did:
log3(3x-5) + log(3-1)12 = 1 - x
log3(3x-5) - log312 = 1 - x
log3 [(3x-5)/12] = 1 - x
and the last line is the same as what I post in #1If I understand it correctly, I think I will come up with the same equation as mine using your idea. Am I correct?
Thanks
logarithm
exponential
Thanks
That can be solved only numerically. Are you sure, it was not log3(3x-5) + log(1/3) 12 = 1 - x?
ehild
Your second line is wrong. Look again at the change of base formula.
ehild
songoku did not say if he is trying to solve the equation or not. If so, you're correct, but he may still want a transformed version of the original logarithm equation.
... In fact, the transformed equation in exponential form can be simplified significantly, still having an x in an exponent and and x term in a polynomial.
Songoku did the transformation correctly. What is log3(1/3) ?
ehild
ehild
No.
ehild
I am sure. I have checked it again.
Why is it wrong?
1/3 = 3-1
and if I have log(an)b I can change it to 1/n . loga b, correct?
It can be a typo in the book then.
You can find approximate solution graphically.
ehild
symbolipoint said:
No.
Well, how do you transform the equation then? Show your result.
ehild
ehild
This is shown in post #2 for the treatment of the term that used the rational base of one-third.
OK let me test it
Use change of base rule, this becomes:
log3(3x-5) + [log3 12] / [log3 (1/3)]= 1 - x
log3(3x-5) + [log3 12] / (-1)= 1 - x
log3(3x-5) - [log3 12] = 1 - x ---> same as what I got ?
songoku said:
OK let me test it
songoku, okay you convinced me. Although you did not quite finish, the work looks good.
ehild is correct, there can be a typo in the book. Plug the equation in wolframalpha.
Using that treatment you also get songoku's result of
[itex]\displaystyle \frac{3x-5}{12}=3^{1-x}[/itex]​
which is correct, as ehild has pointed out more than once.
logarithm
exponential
Thanks
I made a small but very significant arithmetic mistake when I made the equation transformation myself the first time. The equation result which you show is good.
Thanks for all the help given here :smile:
