Solving the Last Practice Problem: A Coast Guard Challenge
  • Thread starter Thread starter anuman
    Challenge
The discussion centers around solving a challenging practice problem related to vector analysis for a Coast Guard scenario. The user struggles with determining the components of vector C, which represents the difference between two vectors A and B. Participants emphasize the importance of correctly resolving each vector into its components and suggest drawing a diagram for clarity. Additionally, they clarify that the user mistakenly performed vector addition instead of subtraction and recommend adding the inverse of the second vector for accurate results. Understanding vector direction and component resolution is crucial for solving the problem effectively.
anuman
I'm studying for an exam and can't seem to get this last practice problem! I've tried many ways but still keep getting the wrong answer. The professor has already given us the correct answer to the problems, but I want to know HOW to do it for the exam! Thanks in advance :)
A boat radioed a distress call to a Coast Guard station. At the time of the call, a vector A from the station to the boat had a magnitude of 45.0 km and was directed 15.0° east of north. A vector from the station to the point where the boat was later found is B = 30.0 km, 15.0° north of east.
12. What are the components of the vector from the point where the distress call was made to the point where the boat was found? In other words, what are the components of vector C = B - A?
x component y component
A)17.3 km, east 35.7 km, south
B)35.7 km, west 17.4 km, north
C)40.6 km, east 51.2 km, south
D)17.3 km, west 51.2 km, south
E)40.6 km, east 35.7 km, north
13. How far did the boat travel from the point where the distress call was made to the point where the boat was found? In other words, what is the magnitude of vector C?
A)65.3 km B)39.7 km C)26.5 km D)54.0 km E)42.5 km
How did you attempt the problem?
Did you first resolve each of the given vectors into their two components?
You should show us your attempt at the problem so we can see where you may have gone wrong.
This is how I attempted it...I have been in the hospital for a while so I don't have class notes.
45sin15=11.64 30sin15=7.76
45cos15=43.46 30cos1515=28.97
11.64+7.76=19.4 y-component
43.46+28.97=72.43 x-component
Careful. Draw a diagram.
I don't think the terms combine in the way that you attempted.
The first vector is 15° to the right of North. This could also be written as 75° north of East if it would help you not to mix the Sines and Cosines.
Also you did a vector addition not a subtraction.
The easiest way to subtract is to add the inverse of the second vector.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
