Solving the Limit of (lnx)^(1/(x-e)) as x Approaches e
  • Thread starter Thread starter apoptosis
    Limit
The discussion revolves around evaluating the limit of the expression (lnx)^(1/(x-e)) as x approaches e from the right. Participants are exploring the application of L'Hôpital's rule and the correct interpretation of the limit's form.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of L'Hôpital's rule, questioning whether it is appropriate for the limit in question. There are attempts to clarify the setup of the limit and the interpretation of the exponent.
Some participants are providing guidance on the correct application of derivatives and the conditions under which L'Hôpital's rule can be applied. There is an ongoing exploration of the limit's behavior and the necessary steps to evaluate it, with no explicit consensus reached.
There is a mention of confusion regarding the notation used in the limit expression, particularly concerning the exponent and the application of derivatives. Participants are also reflecting on their understanding of the limit's form as they approach e.
apoptosis
Heya! Here's a question that I CANNOT solve for the life of me. Thanks for any direction!
lim (lnx)[tex]^{\frac{1}{x-e}}[/tex]
x[tex]\rightarrow[/tex]e+
^^ I'm not sure if Latext is clear, but x-e is an exponent to lnx
So, I'm thinking L'hopital's rule in starting off the question, but I'm not exactly sure if it's the right way. my work so far is in part 3...
To bring the exponent down, I bring in ln:
ln(lnx)[tex]\frac{1}{x-e}[/tex]
so: [tex]\frac{ln(lnx)}{x-e}[/tex]
applying l'hospital's, I find that it results in a 0/0 fraction so I derive:
to get:
[tex]\frac{1}{x)(lnx)(1-e)}[/tex]
However, when I sub in e I get -2.14...so I guess I'm on the wrong track
I did graph the function, where the equation is not defined at e. As I approach e from the right, I get a number of 1.44.
Thank you once again!
to get:
I don't think you did the derivatives right.
Hi, thanks for the reply.
However, I don't see my mistake, it'd be great if you could point it out to me.
I am following l'hopital's rule...so that's why I'm taking the derivative of the numerator and denominator separately instead of the product or quotient derivative rule.
there is no reason to apply l'hospital's rule here! l'hospital's rule is only applyed when you have a limit of the intermediate form [tex]\frac{0}{0}[/tex] or [tex]\frac{\infty}{\infty}[/tex]
[tex]lim_{x\rightarrow\ e^{+}} \frac{ln(x)}{x-e}= \frac{1}{lim_{x\rightarrow\ e^{+}} (x-e)}=\infty[/tex]
Right... but what's the derivative of x-e with respect to x, unless I do not follow?
or wait is this what you meant:
[tex][{ln(x)]^{\frac{1}{x-e}[/tex] because one cannot clearly see what u meant?
If this is the case, than you are on the right track, just double check your result after u applied l'hospital's rule!
So, I think you are on the right track.
Let [tex]L=lim_{x\rightarrow e}ln(x)}^{\frac{1}{(x-e)}}[/tex]
Then [tex]ln(L)=lim_{x\rightarrow e}ln(ln(x)}^{\frac{1}{(x-e)}})=lim_{x\rightarrow e}\frac{1}{x-e} ln(ln(x))[/tex].
I think the problem, then, is this:
[tex]ln(L)=lim_{x\rightarrow e}\frac{ln(ln(x))}{(x-e)}[/tex]
In which case, taking derivatives of the top and bottom gives:
[tex]\frac{d}{d x}(x-e)=1[/tex] (here is where you made your mistake)[tex]\frac{d}{d x}(ln(ln(x)))=\frac{1}{x ln(x)}[/tex]
Then, the limit becomes [tex]lim_{x\rightarrow e}\frac{ln(ln(x))}{(x-e)}=lim_{x\rightarrow e}\frac{1}{x ln(x)}[/tex]
Which is [tex]\frac{1}{e ln(e)}=\frac{1}{e}[/tex]
So, [tex]L=e^{ln(L)}=e^{\frac{1}{e}}[/tex]
Aha! i see...so i just forgot to take the derivative of e's '1' exponent *smacks forehead* all this time and second guessing...
Thank you very much, everyone!
and sorry about the misunderstanding about 1/(x-e) as the exponent. still getting used to Latex. :D
10K
