Solving the wave equation with piecewise initial conditions
  • Thread starter Thread starter songoku
11 replies · 5K views
songoku
Given that u(x,t) is displacement of string vibration, find the solution of the following wave equation based on the initial and boundary conditions:
##u_{tt}=u_{xx}, 0<x<2##
##u(0)=u(2)=0##
##u(x,0)=
\begin{cases}
0.1x & \text{if } 0<x<1 \\
0.1(2-x) & \text{if } 1\leq x<2
\end{cases}##
##u_{t}(x,0)=0##
D’Alembert’s Formula
I have solved the question using formula:
$$u(x,t)=\Sigma_{n=1}^{\infty} \sin \left(\frac{n \pi x}{2}\right) \left[a_n \frac{2}{n \pi} \sin \left(\frac{n \pi t}{2}\right)+b_n \cos \left(\frac{n \pi t}{2}\right)\right]$$
and I get:
$$u(x,t)=\Sigma_{n=1}^{\infty} \frac{0.8}{n^2 \pi^2}\sin \left(\frac{n \pi}{2}\right) \cos \left(\frac{n \pi t}{2}\right) \sin \left(\frac{n \pi x}{2}\right)$$
as the solution.
I want to try using d’Alembert’s Formula: ##u(x,t)=A(x-t)+B(x+t)## where
$$A(y)=\frac{1}{2} \left(F(y)-\int_{0}^{y} G(x) dx \right)$$
$$B(y)=\frac{1}{2} \left(F(y)+\int_{0}^{y} G(x) dx \right)$$
and ##F## and ##G## are and odd periodic extensions of ##f(x)## and ##g(x)## (##f(x)=u(x,0)## and ##g(x)=u_{t}(x,0)##)
For this question, ##g(x)=0## so ##G(x)## is also 0. For ##F(y)##:
$$F(y)=
\begin{cases}
-0.1(2+y) &, -2<y<-1 \\
0.1y & , -1<y<1 \\
0.1(2-y) & , 1\leq y<2
\end{cases}$$
$$A(x-t)=\frac{1}{2} F(x-t)=
\begin{cases}
-0.1(2+x-t) &, -2<x<-1 \\
0.1(x-t) & , -1<x<1 \\
0.1(2-x+t) & , 1\leq x<2
\end{cases}
$$B(x+t)=\frac{1}{2} F(x+t)=
\begin{cases}
-0.1(2+x+t) &, -2<x<-1 \\
0.1(x+t) & , -1<x<1 \\
0.1(2-x-t) & , 1\leq x<2
\end{cases}
So:
$$u(x,t)=A(x-t)+B(x+t)$$
\begin{cases}
-0.2(2+x) &, -2<x<-1 \\
0.2x & , -1<x<1 \\
0.2(2-x) & , 1\leq x<2
\end{cases}
Is this even correct? Is it possible to get the same solution in sigma form using D’Alembert’s Formula?
Thanks
That doesn't look like a proper periodic extension of ##f## at all. Also, ##F## has conditions on its argument, which is ##x - t## or ##x+t##, not ##x##.
It is easier to just describe ##F## on one full period of ##F## and then just refer to it as periodic with that period.
Reply
I am sorry I don't understand the hint.
This is what I thought: F should be periodic in interval (-2, 2). The initial graph of ##f(x)## has the shape of triangle and the reflection about origin will produce inverted triangle for interval (-2, 0). This is the graph with the corresponding equation for each interval:
Is that not the odd periodic extension of ##f(x)##?
Thanks
Thanks
A periodic function repeats once every period forever. Your function is only defined on (-2,2).
Reply
Do you mean I need to use Fourier sine series to represent the periodic function to cover every period forever?
No. You need to somehow specify that your function has a period of 4.
Reply
$$F(x)=
\begin{cases}
-0.1(2+x) &, -2+4t<x\leq -1+4t \\
0.1x & , -1+4t<x\leq 1+4t \\
0.1(2-x) & , 1+4t< x\leq 2+4t
\end{cases}$$
where ##t \in \mathbb Z##
Is this what you mean?
Thanks
songoku said:
$$F(x)=
\begin{cases}
\end{cases}$$
Thanks
That doesn't work; adding 4 to [itex]x[/itex] adds -0.4 to [itex]F(x)[/itex] in the first and third cases and 0.4 in the second case. The function is therefore not periodic.
The idea is to say that if [itex]4n \leq x < 4n+1[/itex] (don't use [itex]t[/itex] for this purpose; the question has already defined that to mean something else) then [itex]F(x) = F_0(x - 4n)[/itex] where [tex] F_0 : [0,4) \to \mathbb{R} : x \mapsto \begin{cases}<br /> 0.1x & 0 \leq x < 1 \\<br /> 0.1(2 - x) & 0 \leq x < 3 \\<br /> 0.1(x-4) & 3 \leq x < 4 \end{cases}[/tex] or perhaps that if [itex]4n - 1 \leq x < 4n+3[/itex] then [itex]F(x) = F_1(x - 4n)[/itex] where [tex] F_1 : [-1,3) \to \mathbb{R}: x \mapsto \begin{cases}<br /> 0.1x & -1 \leq x < 1 \\<br /> 0.1(2-x) & 1 \leq x < 3 \end{cases}[/tex]
Reply
For a function to be periodic, each case of the piecewise function should increase by same amount if we add the period to the function?
This is ##F_1 (x)## so:
$$F_1(x - 4n)=
\begin{cases}
0.1(x-4n) & -1 \leq x-4n < 1 \\
0.1(2-(x-4n)) & 1 \leq x-4n < 3 \end{cases}
Do I interpret that correctly? Thanks
$$F_1(x - 4n)=
\begin{cases}
No, f(x) is periodic with period p if for k Integer, f(x)=f(x+kp).
Reply
The Fourier solution in the original post is correct and it is a periodic function with a period of ## 4 ##.
The d’Alembert solution is correct too, but only for ## t=0 ## and the multiplication by ## 1/2 ## should be included.
Intervals in the expression for ## A(x-t) ## should be changed into ## \begin{cases}...-2\lt x-t\le -1\\...-1\lt x-t\lt 1\\...1\le x-t\lt 2\end{cases} ## and the multiplication by ## 1/2 ## should be included and intervals in the expression for ## B(x+t) ## should be changed into ## \begin{cases}...-2\lt x+t\le -1\\...-1\lt x+t\lt 1\\...1\le x+t\lt 2\end{cases} ## and the multiplication by ## 1/2 ## should be included.
There is a connection between two solutions. See https://www.math.purdue.edu/~eremenko/dvi/dalembert2.pdf.
songoku said:
$$F(y)=
\begin{cases}
0.1y & , -1<y<1 \\
\end{cases}$$
You can add that ## F(x+4n)=F(x) ## where ## n ## is an integer to make ## F(x) ## a periodic function with a period of ## 4 ##. The same holds for ## A(x) ##, ## B(x) ## and the final d’Alembert solution in the original post.
Reply
I am really sorry for late reply
I think I get this.
Thank you very much for all the help and explanation Orodruin, pasmith, WWGD, Gavran
Reply
