Solving Work Needed to Pull Chain On Frictionless Table
  • Thread starter NasuSama
17 replies · 3K views · last reply
NasuSama
A uniform chain has mass m = 7.51 kg and length L = 8.5 m. It is held on a frictionless table with L/12 hanging over the edge. Find the work needed to pull the hanging part back onto the table.
* Must do the energy considerations!
Let's see...
→½mv²
→mgh
Attempt?
½ * 1/12 * m * v² = mgd?
a twelfth of the chain is hanging over the edge of the table
you want to figure out the work needed to raise that twelfth up onto the table.
Figure out how much mass is in that twelfth and how high it needs to be raised in order to be brought back onto the table.
CWatters said:
You only need use mgh not 0.5mv^2.
Why do you need to use mgh?
Then, is it W = 1/12 * mgh?
This is a tricky question! The bottom part of the chain would be the only part where mgh=(infinitesimal fraction of 7.51kg/12)*g*(8.5m/12) would hold true. The top part of the chain would require no work as it is already at table level. The bits in-between would require work proportional to their distances from the table top.
I do believe that without knowing some universal rule, or knowing integral calculus, you'll have to figure out a clever trick to bring all of the mass to one point, without changing the energy of the system, and calculate from there.
That's how I would do it, as I don't know that universal rule, and have forgotten all of my calculus. :redface:
We don't know. You haven't told us what you're using for m, g, and h. If it is the m, g, and h from the original question, then the answer is no. That would only hold true if all of the mass was at the bottom of the chain.
The center of mass of the hanging part of the chain is halfway up that part of the chain. For this kind of problem, you can treat the mass of the chain as concentrated at its center of mass, and use [itex]W=mgh[/itex] with that distance.
If you can use integration, you would simply use [itex]\int^h_0\rho g h' dh'[/itex] where [itex]\rho=M/L[/itex].
How is the center of mass relevant to this problem? I don't see it.
Gravity acts on the center of mass. In most problems where the distribution doesn't change shape and that don't involve torques, you only have to consider forces acting on the center of mass. It's also true for work, since work is just force integrated (or summed) over distance.
Without calculus, it's just...
W = mgh?!
What about the integral part? Is it...
∫^(h' = 0,h) ρgh' dh'
= ∫^(h' = 0,h) mgh'/L dh'
= mgh'²/(2L) | 0,h
= mgh²/(2L)
= mg(L/12)²/(2L)?
Still don't get how to approach this problem. Please help.
Without calculus, the h is the height of the center of mass, (L/12)/2.
You did the integration correct. Both answers give you the same answer of mgL/32.
I brought in center of mass because I wasn't sure if you were doing algebra or calculus based physics. You can just ignore it, since the integral method is more rigorous.
Actually, I need to use energy considerations in any of the two methods - algebra or calculus.
Then, it's just...
W = mgL/32
= 7.51 * 9.81 * 8.5 / 32 ≈ 19.6
Am I on the right track?
How is it that you get mgL/32?
My mistake, I was thinking 16, not 12. It should be 24, not 32.
What about this?
= mgh'²/(2L) | 0,h
= mgh²/(2L)
= mg(L/12)²/(2L)
= mgL²/144 / (2L)
= mgL/288
I just can't do math today. I also forgot to account for the fact that only 1/12 of the mass is hanging for the CoM version, so it should be (m/12)g(L/12)/2=mgL/288.
1/12th of the mass is hanging at an average of 1/24th L below the table.
1/12 * 1/24 = 1/288
So mgl/288 seems right to me.
