Solving x^4 - 8x^2 + 2 = 0 with quadratic formula
  • Thread starter Thread starter akp
6 replies · 3K views
akp
x^4 - 8x^2 + 2 = 0
quadratic formula?
i would've tried using the quadratic formula, but I am not sure if this would work with that seeing as how it's not ax^2 + bx + c
You will need to use the factor/remainder theorem.
The example equation is in quadratic form, or something like it. First, you may use a substitution, something like, t=x^2. This can give you like, this:
t^2 - 8t + 2 = 0
Now, you can solve THAT one and you may obtain two solutions, but those solutions are for t. Now, solve each of those solutions for x (remember to first replace t with x^2 )
The polynomial fortunately is quadratic, but in x2.
If u = x2 then you have x4 -8x2 + 2 = u2 - 8u + 2 = 0.
You can use the quadratic formula to solve for x2 keeping in mind that any negative roots from the formula must be discarded since x2 can never be negative.
--Elucidus
Elucidus said:
...keeping in mind that any negative roots from the formula must be discarded since x2 can never be negative.
--Elucidus
We have this field now called complex numbers that has negitive squares.
i^2=-1 for example
i^2=-1 for example
The thread title is "help with finding all real solutions" so I figured that complex solutions weren't needed.
--Elucidus
--Elucidus
Good point. I like to keep track of the complex roots to assist in tracking the real roots. The fundamental theorem of a algebra impies each complex root means one less real root to find.
