Special Relativity and Black Holes
Einstein's special relativity demonstrates that length contraction occurs for objects moving at high speeds. When considering a mass at rest below the critical density for black hole formation, an observer traveling at relativistic speeds may perceive this mass as having increased density due to the effects of the stress-energy tensor. However, the increase in density alone does not result in the formation of a black hole, as gravity is generated by the stress-energy tensor, which encompasses multiple components beyond density. The energy density at a point increases by a factor of gamma squared due to relativistic velocity transformations.
  • Understanding of Einstein's special relativity
  • Familiarity with the concept of the stress-energy tensor in General Relativity (GR)
  • Knowledge of relativistic velocity transformations
  • Basic grasp of black hole physics and critical density
  • Study the implications of the stress-energy tensor in General Relativity
  • Learn about the conditions for black hole formation and critical density
  • Explore the concept of length contraction in special relativity
  • Investigate relativistic velocity transformations and the gamma factor
Students of physics, astrophysicists, and anyone interested in the interplay between special relativity and black hole formation.
2.71828
Hello Forum,
This is my first post :)
Einstein's special relativity finds that length is contracted if the observer is moving at high speeds. Now, assume there is a mass at rest in space that is below critical density of a black hole. If an observer were traveling at high speeds past this mass, the object will contract; therefore, placing the object above critical density. Are the existence of black holes relativistic?
Yes. In GR, mass, or density, alone does not generate gravity. Gravity is generated by the stress-energy tensor, which is a fully relativistic object. The density is a component of the stress-energy tensor, but its only one component. So while the density term does increase, other terms appear and the net result is that you don't wind up with a black hole.
It may (or may not) be interesting to note that the energy density at a point (T_00 of the stress-energy tensor) increases by a factor of gamma^2 due to a "boost" (a relativistic velocity transformation), because the stress-energy tensor measure energy, and not only do you have a smaller volume after the boost, but the smaller volume contains more energy due to the motion of the particles contained within. Here gamma is 1/sqrt(1-v^2/c^2), the usual relativistic term.
Thanks Pervect. Looks like I got some reading to do on GR. I'm really enjoying this forum website :)
  • · Replies 31 ·
  • · Replies 67 ·
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 51 ·
