Speed of light, propellent incease in mass?
This discussion centers on the challenges of achieving light speed in a spaceship, particularly the implications of mass and energy as velocity approaches the speed of light (c). It is established that while the relativistic effects are perceived differently by observers, the rest mass of the spaceship remains constant, and energy approaches infinity as speed increases. The conversation highlights that propulsion methods such as photon rockets and antimatter factories may be necessary for long-distance travel, emphasizing the importance of energy conservation and the limitations imposed by relativistic physics.
  • Understanding of Einstein's theory of relativity
  • Familiarity with the concept of rest mass versus relativistic mass
  • Knowledge of energy conservation laws in closed systems
  • Basic principles of propulsion systems, including photon rockets and antimatter propulsion
  • Research the implications of relativistic energy and momentum conservation
  • Explore the design and feasibility of photon rockets
  • Investigate Project Rover and its potential applications in modern space travel
  • Study the effects of time dilation on fuel consumption and travel efficiency
Physicists, aerospace engineers, and anyone interested in advanced propulsion systems and the physics of high-velocity travel.
ThoughtProces
So i just came across some information that states that if you were in a spaceship trying to reach the speed of light, since the reacting force is being produced on the spaceship and all mass traveling towards the speed of light increase. This means that fuel mass increases and so does the thrust produced due in part to the increase in fuel mass. So does this mean that as you move towards the speed of light then your energy output would increase proportionally to your velocity?
As far as the spaceship is concerned there is no increase in mass. The relativistic effect is seen by outside observers going at a much different speed.
No.
Remember that the laws of physics do not change with speed. The fuel will work the same, regardless of your speed with respect to any reference point.
So then as you reach the speed of light what is it that limits you from reaching c and or over coming it...doesn't your mass increase to infinity?
If the observer is on the spacescraft, the spacecraft will probably have to lose mass for acceleration. then the only propellants you have available are a) light photons, created using only energy, or b) throwing mass out the back, i.e., using energy to accelerate ions, or chemical propellants
to produce thrust.
If you cannot afford to lose mass, then maybe a laser beam will have to do.
If you want to use a nuclear reactor, then maybe Project Rover should be revived. If you want to use nuclear explosions, then ?
so then its more a matter of the amount of fuel needed to actually get there, increase...
Your rest mass never changes at all, and physicists these days usually prefer to avoid the concept of "relativistic mass" and just talk about energy instead. In the frame of reference where you're approaching the speed of light, your energy does approach infinity as your approach c, so you will never reach c as long as only a finite amount of energy is being used to do work on you and increase your kinetic energy.
I kind of get it, now the actual constant of the speed of light, do physicists know what gives us this universal constant?
sry to correct, i guess its not a universal constant
What you can do is exploit time dilation. If you have a fuel factory on Earth that has some fixed output per unit time, then you can take some of the fuel, travel close to the speed of light and then when you return, you'll have a huge amount of fuel available, allowing you to travel even closer to light and with the larger time dilation you will have even more fuel available when you return.
Post 10 is just plain silly...
Not silly at all. Suppose you have an antimatter factory that works on solar power that is in orbit around the Sun. You have a photon rocket that is powered by antimatter. Your goal is to travel to some distant location in the least possible proper time.
Mass of photon rocket without fuel is M
Define tau to be the time it takes for the factory to produce an amount of M of matter/antimatter fuel for the rocket.
We want to travel to a location that is at distance L = lambda c tau.
What is the optimal strategy that will allow the traveler to arrive at the location in the least proper time?
If you use a inertial guidance system not programmed to deal with relativity (it senses acceleration and multiplies by time to get velocity), you'll think you have accelerated beyond C. But if you look in your rearview mirror, Earth will be closer than your navigation system says it should be.
Conservation
That is wrong. The term "relativistic mass" has been died out. Because just multiplying a constant "c2" we get the energy E= mc2/(1-u2/c2). It can be called " relativistic energy" .
If the mass increases then conservation law will be broken. Mass is conserved. Energy is also conserved but your system's energy can increase because external force works on it. But your system itself does not increase energy.
So, in every closed system, the total relativistic energy and momentum are conserved.
But rest mass is not conserved. For example think of a nuclear bomb where mass is transformed to energy following E=mc2
Post #12 is unrelated to post #10...
I really like the idea of the spaceship traveling close to the speed of light trying to pick up a huge stockpile of antimatter fuel at rest. Some of the resulting little bits of spaceship should definitely get even closer to the speed of light.
If the mission could be done by the year 2109 do you think we will still have the "Darwin Awards"? It seems like a winner to me.
Just solve the problem explained in post 12. What does the solution look like in the limit of large lambda?
You assume that you start with a photon rocket without any fuel.
  • · Replies 51 ·
  • · Replies 130 ·
15K
  • · Replies 45 ·
  • · Replies 25 ·
  • · Replies 64 ·
