Speed of Point on Expanding Sphere
  • Context: High School
  • Thread starter Thread starter Ad VanderVen
    Point Speed Surface
The discussion revolves around the speed of a point moving on the surface of an expanding sphere, particularly in the context of special relativity (SR) and mathematical modeling. Participants explore whether the expansion of the sphere imposes any limits on the speed of a point on its surface.
  • Some participants propose that the speed of a particle on the surface of an expanding sphere is mathematically defined by the relationship ##r(t) = b t##, where ##b## is a positive constant.
  • Others argue that while the mathematical model allows for a speed ##\frac{dr}{dt} = b##, this speed must remain less than the speed of light ##c## according to special relativity.
  • A later reply questions whether the expansion of the surface affects the tangential velocity of an object moving across it, suggesting that clarification of the scenario is necessary to understand the implications of the expansion.
  • Some participants note that there is no purely mathematical limit on speed, but applying the principles of SR introduces a limit.
  • Multiple participants express confusion regarding a link provided in the original post, indicating a potential issue with the discussion's context.
Participants generally do not reach a consensus, as there are competing views on the implications of the expanding sphere on the speed of a point on its surface and the application of special relativity.
Participants highlight the need for clarification on the setup of the situation to fully address the question of speed in relation to the expanding surface.
Ad VanderVen
TL;DR
Suppose we have an expanding sphere. That means that the surface ##4 \Pi r^{2}## is getting bigger and bigger. For example, suppose the area expansion rate is ##b r##. Does this limit the speed at which a point can move on the surface?
Reference: https://www.physicsforums.com/forums/special-and-general-relativity.70/post-thread
Suppose we have an expanding sphere. That means that the surface ##4 \pi r^{2}## is getting bigger and bigger. For example, suppose the area expansion rate is ##b \, r##. Does this limit the speed at which a point can move on the surface?
Limit in what way? In SR the speed of a particle as measured in an IRF is limited by ##c##. Having an expanding physical object, if that is what you mean, doesn't change that.
PS the link in the OP doesn't lead anywhere.
I do not know how to re-edt the summary.
I mean it purely mathematically.
I mean ##r(t) \, = \, b \, t## where ##t## represents time and ##0 \, < \, b##..
And ##r## is the distance from the center of the sphere to a particle on the surface of the sphere (using an inertial frame in which the center of the sphere is at rest)?
Then ##\frac{dr}{dt}=b## is the speed of that particle using that frame. It will of course be less than ##c##.
Report your post, include the correct link in your report, and one of us mentors can fix it for you.
There's no purely mathematical limit on the speed of a particle. But, if you apply the theory of SR, then there is a limit.
Ad VanderVen said:
TL;DR Summary: Suppose we have an expanding sphere. That means that the surface ##4 \Pi r^{2}## is getting bigger and bigger. For example, suppose the area expansion rate is ##b r##. Does this limit the speed at which a point can move on the surface?
So you are asking about the idea of an object that is confined to the expanding surface but which may be moving across that surface?
If the object is "coasting" across the surface, what happens to its speed as the surface expands? Does it retain its original tangential velocity? Or is its tangential velocity amplified by the expansion of the surface?
Neither physics nor mathematics can answer that question. Only clarification on the setup of the situation can answer it.
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 47 ·
  • · Replies 34 ·
