Mentor
- 37,425
- 16,548
Yes, there is a problem. The problem is here:DmitryS said:Do we agree that there is a problem?
That is false.DmitryS said:The source of radiation is the point of space with its respective coordinates, and it has nothing to do with the fact whether the material device is at rest in this point or not.
The source of light is current and charge densities, as described by Maxwell’s equations. Those are material. And, importantly, the charge density ##\rho## and current density ##\vec j## together transform as a four-vector ##(\rho,\vec j)##, called the four-current density. In particular for this conversation, the direction that ##\vec j’## points is not generally the same direction that ##\vec j## points.
This is true, but does not imply that the material lamp is not the source. The source of the wave front is the material lamp at the retarded time. The fact that the source has moved between the retarded time and the measurement time is irrelevant. At the retarded time the lamp was at the origin and the material lamp physically emitted the wavefront at the origin. The lamp is the source.DmitryS said:in either frame in this scenario to have the speed c we will need to measure the distance between the wave front and the ORIGIN OF THE COORDINATES. This is so even for O' where at the moment of the measurement will be no material lamp.
By applying Maxwell’s equations in each frame, properly transforming the material sources in each frame.DmitryS said:How do we choose which sheet to pull at speed v?
If the shots are not identical, on what grounds we choose one of the trajectories to be inclined?
