Sphere-Ellipsoid Metric Transformation at u = 0.99c
  • Context: Graduate
  • Thread starter Thread starter ChrisVer
    Induced
The discussion focuses on the transformation of a sphere's metric to an ellipsoid due to Lorentz length contraction at a velocity of u = 0.99c. In the rest frame of the sphere, it maintains its spherical shape, but when observed from frame S, it appears as an ellipsoid of revolution. The transformation is achieved by applying a Lorentz boost to the parametrization of the 2-sphere, resulting in the new parametrization for the ellipsoid. The induced metric can then be calculated for the 2-surface embedded in ℝ³.
  • Understanding of Lorentz transformations
  • Familiarity with metric tensors in differential geometry
  • Knowledge of parametrization of surfaces in ℝ³
  • Basic concepts of special relativity
  • Study Lorentz transformations in detail
  • Learn about metric tensors and their applications in general relativity
  • Explore the parametrization of surfaces in ℝ³ and their geometric implications
  • Investigate the concept of ellipsoids of revolution and their properties
Physicists, mathematicians, and students of relativity interested in the geometric implications of high-velocity transformations and the behavior of objects under Lorentz contraction.
ChrisVer
Hello,
Suppose you have a sphere, traveling at u = 0.99 c along the x axis in our frame S.
I was wondering how the sphere's metric changes due to Lorentz length contraction. Obviously at the rest frame of the sphere, it will appear as a sphere. However on S the sphere will appear as an ellipsoid.
How would the induced metric transform however, so that it changes from describing a sphere to describing an ellipsoid?
What do you mean by "appear"? Do you mean the intersection of the worldtube of the sphere with the past lightcone of S? If so then you're mistaken, the sphere will still appear as a sphere. If on the other hand you mean the intersection of the worldtube with the simultaneity surfaces of S then yes it will be ellipsoidal; in this case it will be an ellipsoid of revolution since the ##y## and ##z## axes of the ellipsoid will be equal semi-major axes and the ##x## axis will be the smaller semi-minor axis.
The easiest way to get the new metric is to simply take the parametrization of the 2-sphere ##x = \cos u \cos v, y = \cos u \sin v, z = \sin u##, where ##-\pi/2 < u < \pi/2, -\pi < v < \pi## is a frame independent specification, and perform a Lorentz boost at ##t = t' = 0## so that ##x' = \gamma x## giving the parametrization of an ellipsoid of revolution ##x' = \gamma\cos u \cos v, y' = \cos u \sin v, z' = \sin u## from which the new induced metric can be calculated in the usual way for 2-surfaces embedded in ##\mathbb{R}^3##.
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 28 ·
