Spot Student Mistakes: 1/x < x < 1
  • Thread starter Thread starter garyljc
5 replies · 3K views
garyljc
Spot the mistakes of a student
1/x < x < 1
therefore 1<x^2
therefore 1<x
but x<1 therefore there are no solution
the questions requires me to spot the mistake made by a student
so first of all
in the 2nd line , it reads 1<x^2 . this statement is wrong since the student assumes that x is always >0
i'm not too sure about about the second one , namely 1<x . Since it's related to the first one . What should i put ?
is there any other mistakes i have not spotted ?
If you are given the statement x2 > 1, it doesn't necessarily imply that x>1. Consider the case where x=-5. x2=25 which is certainly greater than 1, but x>1 is not true. Again, the student has assumed that x is positive.
so does it mean there's only one mistake ?
If [tex]x > 0[/tex] you can't have
[tex] 0 < \frac 1 x < x < 1 [/tex]
because this is equivalent to
[tex] 0 < 1 < x^2 < x[/tex]
If 1/x < x < 1, it does not necessarily follow that 1 < x^2.
For example, for x=-1/2, we have -2 < -1/2 < 1, but 1 < 1/4 is false.
In fact, the implication is false for all -1 < x < 0.
If the previous post was directed at mine, you missed one of my points.
[tex] 0 < \frac 1 x < x < 1[/tex]
because (if you multiply through the inequality by [tex]x[/tex]) then you would have
My initial comment ruled out negative values from consideration. logarithmic, if I misunderstood you post by assuming it was meant at me, I apologize.
