Spot the Odd Ball: Weighing Challenge in 3 Chances
The discussion revolves around a logic puzzle involving 12 balls, one of which is either heavier or lighter than the others. Participants explore various strategies to identify the odd ball using a weighing machine within three attempts, while also determining whether it is heavier or lighter. The conversation includes both proposed solutions and critiques of those solutions.
  • Some participants suggest dividing the balls into groups for weighing, such as 4 against 4, and propose methods to narrow down the possibilities based on the outcomes of the weighings.
  • Others express skepticism about the feasibility of certain proposed methods, noting that they may not account for the possibility of the odd ball being either heavier or lighter.
  • A participant shares a detailed weighing strategy, outlining steps to identify the odd ball and its weight status, but later acknowledges potential flaws in their reasoning.
  • Some participants comment on the frequency of this puzzle being posted in the forum, indicating a shared familiarity with the problem.
  • There are humorous interjections regarding the nature of the puzzle and its presentation, reflecting a light-hearted tone amidst the technical discussion.
Participants do not reach a consensus on the best method to solve the puzzle, with multiple competing strategies and critiques of those strategies present throughout the discussion.
Some proposed solutions rely on assumptions about the outcomes of weighings that may not hold true, and there are unresolved mathematical steps in the reasoning presented by participants.
Individuals interested in logic puzzles, mathematical reasoning, and problem-solving strategies may find this discussion engaging.
Xalos
You have 12 balls, and a weighing machine with no standard weighs. One of those 12 balls is either lighter or heavier than the others. Spot the ball in 3 chances with the weighing machine.
Mathematics news on Phys.org
hint:
2x6, 2x3, 2x1+1
or 2x4+4, 2x2, 2x1
Sorry, I forgot to mention that you must also be able to say whether the ball is heavy or light.
This "puzzle" has been posted a zillion times here...
Maybe not a zillion times, but more than 5 times.
Xalos said:
You have 12 balls
I've had that dream before. Kind of a nightmare, actually. It was impossible to walk or sit down.
Oh! Okay.
6 vs. 5 + 1 lighter. Get the lighter set.
3 vs 2 + 1 lighter. Get the lighter set.
Weigh any 2 of them. If they are equal, the 3rd one is lighter.
Thank you. I actually have spittle on my screen.
It is not ok: the defective ball could be in the heavier set .
Oh craps. I didn't notice that it could be lighter or heavier.
The puzzle is new to me, so here's my answer:
Weigh 4 against 4.
If they even out, select three and weigh against 3 from the remainder. If they cancel out still, and since there's 1 ball left, one more weighing will give away the answer. If not, then the foreign ball is within those 3 balls selected from the remainder. At this step, it should be clear whether the foreign ball is lighter or heavier than the others. Now say the said balls are A B C, and other random balls now known to be normal are X X X. Weigh A X against B X. If they even out, then obviously it's C, if not, then either A or B.
Now if 4 against 4 doesn't cancel out, substitute one side with the remainder. Depending on what the scale reads, determine whether the foreign ball is lighter or heavier. In any case, you'll end with a 2 against 2 weighing, which will easily give away the foreign ball by swapping two balls from each side, and substituting for 1 ball from the remainder on one side.
I've told you a million times: don't hyperbolize!
<snip>
I am pretty positive the bolded part would not work.
You're right, what I wrote is senseless. Impossible to determine a foreign ball out of 4 balls with only one weighing. I'll try rectifying the solution, tomorow
You are right, Dave!
Even my mother has already told me this a billion times...
Ok here's the correction:
4 against 4 doesn't even out
Say we have on the heavier side A B C D and on the lighter side S T U V, and X represent a ball from the remainder. Now weigh S X X X against A T U V. If they even, out, the foreign ball is among B C D, and is heavier. If S X X X > A T U V, then the foreign ball is among T U V and is lighter. If S X X X < A T U V, weigh A against X. If A = X, then S is the foreign ball, and is lighter. If A > X, then A is the foreign ball and is heavier.
Solved :biggrin:
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 59 ·
