SR-time dilation vs GR-time dilation on rotating Earth
79 replies · 6K views
cianfa72 said:
the question is: what is the ##r## coordinate ? I don't think it is the ##r## coordinate of Schwarzschild coordinates in Schwarzschild spacetime (i.e. it doesn't have the same significance/feature as "reduced circumference").
I believe the usual radial coordinate for frames like the ECI frame is the isotropic radial coordinate, not the Schwarzschild radial coordinate--i.e., the coordinate is defined so that locally, radial coordinate increments are the same physical distance as tangential coordinate increments (i.e., ##dr## vs. ##r d\theta## or ##r d \phi##).
However, in the weak field, slow motion approximation, it doesn't really matter; the Schwarzschild and isotropic radial coordinates both have the same weak field, slow motion limit. In that limit, spatial coordinate increments are as if the space was Euclidean, i.e., the difference is too small to matter when compared with the difference in increments of the time coordinate vs. proper time.
You mean Cartesian spatial coordinate increments (in ECI frame) are as if the space was Euclidean.
You mean the difference in increments of time coordinate vs. proper time (along the integral curves of ##\partial_t##) is much more large than the difference/discrepancy between Cartesian spatial increments vs. proper distance (along the integral curves of ##\partial_x##, ##\partial_y## or ##\partial_z##).
Euclidean space can be described by coordinates other than Cartesian. In spherical coordinates the relevant increments, as I've already posted once, would be ##dr##, ##r d\theta##, and ##r d \phi## (actually the last is only correct in the equatorial plane, elsewhere it would be ##r \sin \theta d \phi##).
Yes.
Ok therefore, even though the spacelike hypersurfaces of constant coordinate time ##t## are not Euclidean around the Earth, we can use in ECI frame Cartesian coordinates centered on Earth's center (with ##x##,##y## axes on ecliptic plane oriented along the vernal equinox and celestial equator and ##z## along the Earth's rotating axis) given as "inverse mapping" of ##(r,\theta, \phi)## where ##r## is the isotropic radial coordinate. It is defined such that locally the proper distance for increment ##dr## along ##\partial_r## is the same as proper distance for increments ##rd\theta## and ##r\sin \theta d\phi## along ##\partial_{\theta}## and ##\partial_{\phi}## respectively.
All this is just repeating things that have already been said.
The first step of doing a calculation is finding a metric. The most realistic choice is NOT going to be Kerr or Schwarzschild, because the Earth is not an idealized black hole. Since the OP is still asking about which metric to use, I don't think they are prepared to do a calculation as of yet, and that if they think about the steps they need to do a calculation, the first one is to find a metric.
I'm pretty sure the OP has at least seen Neil Ashby's rather famous paper on relativity in the GPS, for instance https://www.aapt.org/doorway/tgru/articles/ashbyarticle.pdf. But really, there are a lot of possible choices, and it's the OP's job to make one. My impression is that they are struggling to conceptually answer the question of what metric to use, I can and have made some suggestions that might be interesting.
So the first thing I would point out is that this paper does (IIRC) give some suggestions as to a metric.
The ones I would suggest are Ashby's paper (not my favorite, but the OP uses a lot of language from it, so I think it's a paper that they've read that may be important to their thought process), Misner's "Precis of General Relativity" which is basically a response to Ashby's paper (I prefer Misner's approach over Ashby's, it's at least worth reading). I'm also partial to MTW's treatment of PPN theory in "Gravitation".
Honoroable mention should be given to the IAU's approach, as a highly accurate one that's of obvious official interest, but it is probably not the best place to start. This has several revisions, so one would have to pick one.
As an overview: Basically rather than using an exact analytical solution that doesn't fit the actual Earth , such as Schwarzschild or Kerr, I would use some model based on the linearized gravity.
After one has picked one (or more) metrics of interest that one believes model the metric of space-time around the Earth, then one is in a position to do one or more calculations and compare the results and look at the significance of various effects.
I'm not quite sure why the OP is so focussed on coordinates, it's rather like they know that methods independent of a particular coordinate chart exist but they've forgotten this? Anyway, this is all a bit of a reahsh, unsuprisingly.
I'd also suggest looking at what we know about the Earth, for instance https://nssdc.gsfc.nasa.gov/planetary/factsheet/earthfact.html, and suggest that some basic parameters of interest are GM, and J2. A brief theoretical diversion into into "potential theory" (see Goldstein's classical mechanics, the chapter on the Earth-moon system and the figure of the Earth) might help explain why J2, a ratio of moments of particular interest.
Anyway, I'm not holding my breath, but maybe we can move past "Should I use Schwarzschild or Kerr" :).
pervect said:
The first step of doing a calculation is finding a metric.t
I am going to disagree.
The first step is to write down what you want to calculate - e.g. the local time that elapses at the equator for each second that elapses at the poles. Δt/t equals something.
I would also suggest that the next step is to try and avoid a metric. Can you solve this by combining solutions you already know? This was suggested - and ignored - around 50 messages ago.
pervect said:
I'm not quite sure why the OP is so focused on coordinate
More generally, I am not sure why he has no apparent focus on actually solving the problem - a problem he himself posted. He's posted a lot of messages, and I struggle to find evidence that he can work any problem in GR at all. Maybe not even SR. That, of course, makes it difficult to discuss more difficult problems.
Let me add one more thing to your list - decide how good your answer has to be. There is zero point to worrying about part per trillion nonlinearities if you know where your clock is to a few meters.
I read that paper. In section II he defines the ECI frame as
locally inertial frame whose origin is attached to the center of the earth but which is not rotating. This is called the “Earth-Centered Inertial,” or ECI frame.
So the Earth's center is at rest at the ECI frame's origin while it free-falls towards the Sun. He claims that the effect of the Sun (including other solar system bodies) comes in only through tidal forces (i.e. tidal gravitational potential) which, from the point of view of satellite's GPS clocks, can be disregared since negligible.
According to him light propagation in ECI frame takes place with constant speed ##c## in any direction. He then writes 4 equations describing in ECI frame the propagation of light signals from 4 GPS satellites up to a terrestrial receiver. Each equation is basically the equation for light propagation in standard inertial coordinates as if spacetime were flat (Minkowski).
From the discussion in this thread, actually Cartesian coordinates for ECI frame are not Euclidean in the sense that the metric on spacelike hypersurfaces of constant time is not Euclidean (even though the spacetime can be assumed to be stationary).
But also from the discussion in this thread, the error involved in treating the ECI frame Cartesian coordinates as if they were Euclidean, i.e., treating the metric on spacelike hypersurfaces of constant time as if it were flat, is negligible for practical purposes. That's why Ashby does so in the paper.
So his locally in "locally inertial frame whose origin is attached to the center of the earth" actually spatially extends from the Earth's center up to locations of GPS satellites orbits. Furthermore, due to the constancy of light speed in ECI frame, clocks at rest in it can be Einstein's synchronized consistently.
Yes.
Clocks at rest, yes. But no clocks that are in common use by anyone on Earth are at rest in the ECI frame. They are either at rest on the rotating Earth, meaning they are moving in the ECI frame at Earth's rotation speed, or they are in free-fall orbits, like the GPS satellite clocks, and are moving in the ECI frame at free-fall orbital speed.
At the risk of derailing the thread by actually discussing the problem:
1. Can one treat the gravitational time dilation from the earth as a geoid? And how different from a sphere is this?
2, A body in orbit an inch above the Earth's surface will experience, a) about the same time dilation as from gravity, b) many, many times more, or c) many, many times less?
3. An object at rest on the Earth is going, a) near orbital speed, b) much faster than orbital speed, ir c) much slower than orbital speed.
Now you have everything you need to solve your problem. No Kerr Metric, no odd coordinate systems, nothing bit algebra needed.
Coming back to the main point: in the approximation given by Ashby's paper the spacetime around the Earth (for pratical purposes in a sufficient large spatial volume around it) is assumed to be flat (Minkowskian). However in ECI frame there exists a gravitational potential (alike the Newton gravitational potential in inertial coordinates). This potential and the kinematic motion of the points on the geoid (i.e. the geoid's timelike worldlines which are members of its worldtube) in ECI frame give rise to an effective potential in that frame which is "responsable" for the shape of the geoid itself.
Wrong. The spacelike surfaces of constant coordinate time are assumed to be flat. That is not the same as the spacetime being flat.
Ah ok, therefore, as far as I understand, Ashby's paper assumes a stationary spacetime. The coordinate time ##t## is "adapted" to the timelike KVF (i.e. the vector field ##\partial_t## is the timelike KVF). Since spacelike hypersurfaces of constant coordinate time ##t## are assumed to be flat (Euclidean), one can pick a set of timelike worldlines filling the spacetime such that, on each of those spacelike hypersurface, they define cartesian coordinates "at rest" in ECI frame.
Yes.
Yes.
They define the ECI frame itself. It makes no sense to say coordinates are "at rest in the ECI frame". The coordinates are the frame.
Yes, I was sloppy. I meant that within the congruence of timelike worldlines that define the ECI frame (by definition they are "at rest" in the frame being defined), one can pick specific members for the "coordinates grid" - Cartesian coordinates with origin in the Earth's center and ##x,y,z## axes as described in post #64 for instance.
The worldlines by themselves don't define a complete frame. Only the worldlines plus a particular choice of spatial coordinates to label them defines a unique frame. You have already been given references for how the ECI frame is defined.
