Stability of Nonlinear System: Can the Zero Solution be Nominally Stable?
5 replies · 2K views
alejandrito29
i need show that at the following system the zero solution is nominally stable, using some change of variable that transforme in a linear system
[tex]\frac{dx}{dt}=-x + \beta (x^2+ y^2)[/tex]
[tex]\frac{dy}{dt}=-2y + \gamma x y[/tex]
i tried with the eigenvalues of the Jacobian matrix at (0,0), but one of them is positive , then the system is unstable...
What does the linearized matrix look like?
What point are you linearising about?
OK now I see you say only (0, 0) is required. Doesn't seem to me you need any transformation for that point.
If I am not mistaken there is the possibility of three 'equilibrium' points - the other two may be more interesting than (0, 0).
the problem says:
"show that the zero solution is nonlinear stable. For this, find the change of variable that transforms this system in a linear system"...
i don't understand
alejandrito29 said:
the problem says:
i don't understand
Can anyone tell me what 'nominally stable' means? I know what 'locally stable' is, which would usually be the question.
To transform the whole system in which there are in general three different stationary points into a linear one would seem on the face of it impossible, isn't it?:rolleyes:
