Steps on the way to Lightcone cosmological calculator
86 replies · 69K views
Spooky action at a distance
mfb said:
This term is used in a completely different context, and has nothing to do with light of old galaxies.
Jorrie:
Thank you. I understand the term is generally used in a QP context. My son has a sense of humor. He was transcending parsecs and Hubble and red shift. Do you have any thoughts on the existential question?
Neko
Astronomy news on Phys.org
marcus said:
It's great to have a Cosmic Event Horizon column!
It is regrettable that Jorrie is inactive at the moment. I hope you can help , marcus.
According to the calculator, the horizon now is just a liitle greater than the radius (14.4 vs 16.4), why so? we know that the ant always reaches its goal, however distant, even if the VErubber espansion rate is 100 000 times greater than its own speed vant.
Why such a great difference here? Are the formulas different? The conditions seem nearly the same,
nay, much better since recession speed VEU ≈ Vlight.
The link says the formula for Dhor is 1/S ∫S0 dS/H,
where can I find the original formula and an explanation?
Thanks
The "ant always reaches its goal" only in the case of coasting or decelerating models, because they have an infinite cosmic event horizon radius. In an accelerating model, the Hubble radius (1/H0) always tends towards the event horizon radius as time goes on.
bobie said:
Why such a great difference here? Are the formulas different? The conditions seem nearly the same, nay, much better since recession speed VEU ≈ Vlight.
I do not quite understand your question, but the relationship between the time light took to reach us (observably universe), the Hubble radius and the event horizon is graphically shown in an attachment (graph from calculator)
Hi Jorrie, I am so glad you replied! I have a few questions nobody could answer.
Can you explain the difference between a stretching rubber balloon and the stretching space?
If you refer to the growing rate of expansion, that is really microscopic, even if it did fluctuate it is on the average ≈1/T0, we can easily consider it stable and Ve ≈ C.
If you refer to other factor please expand on it.
I was referring to the formula of the rubber band,which is so different from the one you are using, but probably when you explain the difference it will all be clarified.
One more thing:
what is and what is the formula for V now/then? In the link I did not find them and nobody could tell me.
For example for S = 1090 Vthen is 3.15c does it mean the (apparent) recession speed is 3.15c?
and Vnow is 66.18, what does it represent? and what is the formula, [tex]1090 = \sqrt{\frac{c+v}{c-v}}[/tex]
Thanks a lot, again
Bobie, the expanding/stretching balloon is no more than a simple analogy to make a small part of cosmology (most importantly, the distance/redshift relationship) easier to understand - space is nothing like rubber! Stick pennies onto a partially inflated balloon and when it is blown up further, the distances between the pennies change according to Hubble's law. That's all there is to it.
bobie said:
If you refer to the growing rate of expansion, that is really microscopic, even if it did fluctuate it is on the average ≈1/T0 ...
No, I think you are confusing the growth of the apparent radius of the observable universe (which grows at c in appropriate units) with the growth of the distance between remote galaxies. The observable universe depends solely on the time since the BB and its radius is not a distance in the true sense of the word. Expansion rates refer to the change of the proper distance between galaxies over time.*
bobie said:
... what is and what is the formula for V now/then? In the link I did not find them and nobody could tell me. For example for S = 1090 Vthen is 3.15c does it mean the (apparent) recession speed is 3.15c?
The expansion rate changes drastically over the history of the universe and there is no simple "V now/then" formula, but the V's are readily calculable from the Hubble parameter H against expansion factor and time. Refer to this Wiki that Markus, Mordred and I worked on some time ago.
-J
* See the definition of Dnow in the "Show columns definition and selection" (hover over the question mark) in LightCone 7.
LightCone7zeit has undergone a minor enhancement of the charting function.
The Chart Options area is opened/closed from the main screen. It allows more customizable charts, limited only by what Google Charts will allow.
It only works in the 'zeit version' of LightCone7 at present. If deemed useful, the standard 'billion years version' could also be upgraded with this functionality in future.
Regards
Jorrie
Hi, @Jorrie
We've just had a thread in which a poster wanted to see the evolution of Hubble constant with time. @marcus posted a graph from the 7zeit calculator, but those units the calc uses are not the easiest to comprehend for a neophyte. On the other hand, I've noticed that there is no H column available for display in your other calc (light cone 7). There is the reciprocal (Hubble radius) there, so adding Hubble constant should be relatively easy (not that I know anything about programming).
Do you think you could add such a column as an optional selection for further reference in the non-zeit calculator?
Bandersnatch said:
Hi, @Jorrie
Yes, it is easy and I already have a draft version of the 'standard' LightCone7 with the H column. The reason for not having released it yet is that I have not decided on the units for graphing it - it has rather awkward units; either it is way smaller than 1 (presently 0.069/Gy), or it is way larger than 1 (68 km/s/Mpc). I was thinking about making it H/Ho, which will pitch it around unity for the present epoch, but then it is still pretty small compared to R, T etc.
In tabular form it obviously does not matter too much, but then one of LightCone's greatest features is the charting...
My thoughts might not be pertinent, but I'm glad to see you both in this thread. Here's how I might explain to a neophyte.
H(t) is an instantaneous speed-to-size ratio.
It is what you multiply a distance of size D by to get the speed that distance is expanding.
So the clearest way to express H0 = H(now) is [itex]\frac{1}{14.4 Gy}[/itex]
If you take the distance 14.4 Gly and multiply by that, you get [itex]\frac{14.4 Gly}{14.4 Gy}[/itex] namely the speed of light, which is the right thing.
If you take any other largescale distance and multiply by [itex]\frac{1}{14.4 Gy}[/itex] you get the speed that distance is currently expanding.
Maybe it would be possible to get the neophyte to understand that because it is a speed-to-size ratio the natural type of units to express it in is Time-1.
Once that is understood Jorrie would have a fair amount of freedom in choosing the units compatibly.
Proposed updated LightCone 7 (standard units) and default column selections. The value H/Ho seems to fit best into the scheme of things...
[tex]{\scriptsize\begin{array}{|c|c|c|c|c|c|}\hline T_{Ho} (Gy) & T_{H\infty} (Gy) & S_{eq} & H_{0} & \Omega_\Lambda & \Omega_m\\ \hline 14.4&17.3&3400&67.9&0.693&0.307\\ \hline \end{array}}[/tex] [tex]{\scriptsize\begin{array}{|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|} \hline S&T (Gy)&R (Gly)&D_{now} (Gly)&D_{then}(Gly)&D_{hor}(Gly)&V_{gen}/c&H/Ho \\ \hline 1090.000&0.000373&0.000628&45.331596&0.041589&0.056714&21.023&22915.263\\ \hline 339.773&0.002496&0.003956&44.183524&0.130038&0.178562&10.712&3639.803\\ \hline 105.913&0.015309&0.023478&42.012463&0.396668&0.552333&5.791&613.344\\ \hline 33.015&0.090158&0.136321&38.051665&1.152552&1.651928&3.200&105.633\\ \hline 10.291&0.522342&0.785104&30.917756&3.004225&4.606237&1.782&18.342\\ \hline 3.208&2.977691&4.373615&18.247534&5.688090&10.827382&1.026&3.292\\ \hline 1.000&13.787206&14.399932&0.000000&0.000000&16.472274&1.000&1.000\\ \hline 0.312&32.884943&17.184900&11.117770&35.666086&17.224560&2.688&0.838\\ \hline 0.132&47.725063&17.291127&14.219438&107.785602&17.291127&6.313&0.833\\ \hline 0.056&62.598053&17.299307&15.535514&278.255976&17.299307&14.909&0.832\\ \hline 0.024&77.473722&17.299802&16.092610&681.060881&17.299802&35.227&0.832\\ \hline 0.010&92.349407&17.299900&16.328381&1632.838131&17.299900&83.237&0.832\\ \hline \end{array}}[/tex]
I have uploaded LightCone7s (the 's' for "standard units") if anyone wants to play with it. Not in my sig. yet, since some bug may still lurk somewhere. The main change in the user interface is that the chart options was transferred from LightCone7z and the "set default chart range" has disappeared - it is redundant now. It will also disappear in LightCone7z in due course.
-J
I don't get it.
marcus said:
Note that the CEH is different from the Hubble radius. The Hubble radius is the distance that is growing at rate c. It is currently 13.9 Gly and the CEH (the reachable radius) is 15.6 Gly.
I think you know this but I'll say it just in case others read this.
why is the CEH different from the Hubble?? If the distance between Earth and a galaxy (proper distance) is greater than 13.88 billion light years then the expansion is greater than light can travel so it will never get there ?
Gaz said:
I don't get it.
Consider that the Hubble radius is the reciprocal of the Hubble constant.
Now, what happens to a light signal at the present edge of the Hubble sphere if the Hubble constant goes down with time?
Yes. Look at the table and graph in post #72 above.
The value of interest is ##H/H_0## and how it changes with time - this is the fractional change, so e.g. a value of 2 means twice the present value of ##H_0##, which is 67-ish km/s/Mpc.
-J
Thanks Jorrie I'll have to update the link to my webpage when the product is finalized. It's unfortunate I can't use this on another forum I've been actively supporting. (More due to the other sites latex structure). Though I do advertise your product on that forum. I found they needed my help far more than here, as their is plenty of expertise on this forum. I've been of greater help on the other forum.
(If your looking at aspects to add, might I recommend adding density to temperature relations ie the thermodynamic relationships)
LightCone7s (for "standard"), now appears together with LightCone7z (for "zeit based") in my signature below. Both have the same "LCDM-engine", the only difference being the units being worked in. Billion years (Gy) for "version s" and zeit for "version z". One zeit is simply time divided by 17.3 Gy, a natural timescale of the LCDM model.
The update from '7' to '7s' is about flexibility in specifying the graph formats, as can be seen under the button "Open Cart Options" (the green area of the LightCone7 (partial) screen shot shown below).
Eventually, there is a beta-test version available with some additions on density, density parameters and temperature. It is not the 'Forum official' version yet, but it has other interesting changes. E.g. inputs or now more standard - I have done away with Hubble times as input parameters, because they are not the ones used in the literature. Prime inputs are now the Hubble constant in conventional units, the total density parameter and the radiation-matter equality redshift parameters. The matter density parameter is then still a derived value.
The range of calculations are also requested as the more conventional redshift (z) in lieu of the simpler, but less well known "S" parameter. Lastly, the output scaling option for "Zeit" has been left out, since it is a potentially non-standard distraction. I hope the updates will enhance the use of the calculator in the educational field.
The latest beta-test version is available as: LightCone7-2017-01-26.
Edit: we found an error in Omega-calculations of this version. See the thread https://www.physicsforums.com/threads/evolution-of-the-energy-density-parameters.901681/
The corrected version is: LightCone 7, Cosmo-Calculator (2017-1).
Comments/suggestions welcome. I will start a new thread to discuss some of the more subtle aspects of the density parameter calculations.
The usage parameters such as ones found in intro level textbooks is probably the most familiar approach and the one that will probably gain the most usage. The parameters you mentioned being the key ones. People are more familiar with redshift than stretch for example. I agree the best approach should be literature based.
I should have time to help update the user manuals when the testing is done if you'd like my help again on that. I still remember how to edit and text on wikidot
After some more comments and further testing, it seems like the updated calculator has stabilized on this version: LightCone7-2017-01-30.
I suggest that we leave it for another week in 'testing mode' and then I will 'release' it into the same url as the previous release, so that no links/sig's need to be updated.
I've been running various tests as time allows. I haven't found any issues that I can see thus far
Thanks for your effort, Mordred. I have used a specific set of columns as default to highlight the new features, but it may now be time to choose a more general set. It should still be limited so as to not being frightening to newcomers.
Any suggestions.
I have now changed the link in my Sig below to the latest version that we have tested, with a very basic set of columns as the default, i.e.
[tex]{\small\begin{array}{|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|} \hline z&T (Gy)&R (Gly)&D_{now} (Gly)&Temp(K) \\ \hline 1.09e+3&3.72e-4&6.27e-4&4.53e+1&2.97e+3\\ \hline 3.39e+2&2.49e-3&3.95e-3&4.42e+1&9.27e+2\\ \hline 1.05e+2&1.53e-2&2.34e-2&4.20e+1&2.89e+2\\ \hline 3.20e+1&9.01e-2&1.36e-1&3.81e+1&9.00e+1\\ \hline 9.29e+0&5.22e-1&7.84e-1&3.09e+1&2.81e+1\\ \hline 2.21e+0&2.98e+0&4.37e+0&1.83e+1&8.74e+0\\ \hline 0.00e+0&1.38e+1&1.44e+1&0.00e+0&2.73e+0\\ \hline -6.88e-1&3.30e+1&1.73e+1&1.12e+1&8.49e-1\\ \hline -8.68e-1&4.79e+1&1.74e+1&1.43e+1&3.59e-1\\ \hline -9.44e-1&6.28e+1&1.74e+1&1.56e+1&1.52e-1\\ \hline -9.76e-1&7.77e+1&1.74e+1&1.61e+1&6.44e-2\\ \hline -9.90e-1&9.27e+1&1.74e+1&1.64e+1&2.73e-2\\ \hline \end{array}}[/tex]
There are now a total of 18 selectable columns, including the actual density against redshift and also the various density parameters (the Omegas).
It is very easy to change the default columns in the program, so please let me know if you want to see other columns as default.
The idea of a small selection is to not overwhelm newcomers with too much data.
marcus said:
The new A20 tabular calculator let's you look at changing geometry out to about 88 billion years according to the standard LCDM cosmic model (with usual estimates for the parameters.).
http://www.einsteins-theory-of-relativity-4engineers.com/CosmoLean_A20.html
It's pretty neat. Here is one sample tabulation. Red stuff is just the three standard parameters, estimated based on observation. No reason to change them, although in this calculator you CAN change them and play around to see the effects.
The blue stuff is what I put into give bounds and step size for the table I wanted it to generate
From the present (S=1) to the distant future (S=0.01) when distances are 100 times what they are today. In steps of ΔS = 0.09. those are just what I chose. If you choose a smaller step size like ΔS = 0.01 you get a table with more rows, like around 100 rows instead of only 12 rows. I won't bother to align the columns. It's probably legible as is.
===quote===
Hubble time now (Ynow) 13.9 Gy Change as desired (9 to 16 Gy)
Hubble time at infinity (Yinf) 16.3 Gy Change as desired (larger than Ynow)
Radiation and matter crossover (S_eq) 3350 Radiation influence (inverse: larger means less influence)
Upper limit of Stretch range (S_upper) 1.0 S value at the top row of the table (equal or larger than 1)
Lower limit of Stretch range (S_lower) 0.01 S value at the bottom row of table (S_lower smaller than S_upper)
Step size (S_step) 0.09 Step size for output display (equal or larger than 0.01)
Stretch (S) Scale (a) Time (Gy) T_Hubble (Gy) D_now (Gly) D_then (Gly)
1.000 1.000 13.769 13.896 0.000 0.000
0.910 1.099 15.104 14.387 -1.219 -1.339
0.820 1.220 16.630 14.829 -2.536 -3.093
0.730 1.370 18.374 15.221 -3.884 -5.320
0.640 1.563 20.402 15.545 -5.270 -8.234
0.550 1.818 22.772 15.812 -6.676 -12.138
0.460 2.174 25.618 16.006 -8.108 -17.627
0.370 2.703 29.120 16.143 -9.555 -25.825
0.280 3.571 33.629 16.233 -11.010 -39.323
0.190 5.263 39.934 16.278 -12.474 -65.650
0.100 10.000 50.390 16.296 -13.939 -139.393
0.010 100.000 87.919 16.300 -15.406 -1540.607
For the model used, see this thread on Physicsforums.
=====endqquote=====
what this tells you, among other things, is which of the galaxies out there you can reach if you flash a signal to them today.
It says ANYTHING THAT IS TODAY NEARER THAN 15.4 BILLION LY is a target you can reach if you flash a message today, and it will get there WITHIN 88 BILLION YEARS.
It also says that 88 billion years from now is when distances will be 100 times what they are today (cosmological distances, not dimensions of bound structures like a rock or solar system)
So if you select a galaxy which is today 15.4 billion LY and you flash a message today, when the message finally gets there the distance to the galaxy (and the message arriving at it) will be 1540 billion LY.
You can read that off the table too.
Is there anyone to whom this does NOT make sense. This is a great calculator and an interactive version of the standard cosmic model that is in professional use (LCDM) and there must be plenty of people who can explain if you find anything obscure about the table. Everybody should get so they understand the table outputs of this calculator both of past history and of the future, IMHO. They are basic.
This is the actual distance of the object (15.4 billion light years), not the distance we would observe it at, which would be nearer to 8 billion light years. The 15.4 Gly has already been corrected for the expansion of the universe since the light we currently can see was emitted.
