Stokes' Theorem Example Question
6 replies · 3K views
Master1022
Summary:: This question is about a Stokes' Theorem question that I saw on Khan Academy and I am trying to attempt to solve it a different way.
The problem is as follows:
Problem: Let [itex]\vec{F} = \begin{pmatrix} -y^2 \\ x \\ z^2 \end{pmatrix}[/itex]. Evaluate [itex]\oint \vec F \cdot d \vec {r}[/itex] over the path [itex]C[/itex] in the CCW direction where C is given by the intersection between [itex]x^2 + y^2 = 1[/itex] and [itex]y + z = 2[/itex].
My attempt:
So I first started by noting Stokes' Theorem: [itex]\oint_C \vec F \cdot d \vec {r} = \iint_S (\nabla \times \vec F) \cdot d \vec S[/itex].
I thought to find the normal vector [itex]\hat n[/itex]:
[tex]\hat n = \frac{\nabla (y + z - 2 = 0)}{||\nabla (y + z - 2 = 0)||} = \frac{1}{\sqrt{2}} \begin{pmatrix} 0 \\ 1 \\ 1 \end{pmatrix}[/tex]
Then I went to find the curl of the surface:
[tex]\nabla \times \vec F = \begin{pmatrix} 0 \\ 0 \\ 1 + 2y \end{pmatrix}[/tex]
and therefore: [itex](\nabla \times \vec F) \cdot (\hat n dS) = \frac{1 + 2y}{\sqrt{2}} dS[/itex]
Then I chose to evaluate the integral in polar coordinates: [itex]x = r\cos(\phi), y = r\sin(\phi), z = 2 - r\sin(\phi)[/itex]. I let [itex]dS = r dr d\phi[/itex] and I used the limits r: 0 to 1 and [itex]0 \leq \phi \leq 2\pi[/itex]. However evaluating this gives me the answer [itex]\frac{\pi}{\sqrt{2}}[/itex], when the video shows that the answer is [itex]\pi[/itex]. I realize that this must have to do with my evaluation of [itex]d \vec S[/itex], and is perhaps suggesting that I shouldn't normalised the normal vector.
Would anyone be able to help shed some insight on this for me? Thanks in advance.
[Moderator's note: Moved from a technical forum and thus no template.]
Master1022 said:
I let dS=rdrdϕdS=rdrdϕ dS = r dr d\phi
In general, it is far easier to treat ##\hat n## and ##dS## together as
d\vec S = \hat n \, dS = \left(\frac{\partial \vec x}{\partial s} \times \frac{\partial \vec x}{\partial t}\right) ds\, dt,
where ##t## and ##s## represent any choice of coordinates on your surface.
Also, note that your plane is not parallel to the x-y-plane. Your assumed dS is only valid if it is.
Thank you very much. I think I have skipped steps in just trying to reduce the problem to the [itex]x-y[/itex] plane.
I just have one or two quick follow up questions based on that:
1) So should I have gone about that part of the working like: ?
[tex]\vec S = x \hat i + y \hat j + ( 1 - x - y ) \hat k[/tex]
[tex]\frac{\partial \vec S}{\partial x} = \begin{pmatrix} 1 \\ 0 \\ -1 \end{pmatrix} , \frac{\partial \vec S}{\partial y} = \begin{pmatrix} 0 \\ 1 \\ -1 \end{pmatrix}[/tex]
[tex]\hat n dS = \frac{\partial \vec S}{\partial x} \times \frac{\partial \vec S}{\partial y} = \begin{pmatrix} 1 \\ 1 \\ 1 \end{pmatrix} dx dy[/tex]
So is this telling me that an 'elemental area' on the surface of the plane is [itex]\sqrt{3}[/itex] times larger than the area [itex]dx dy[/itex] in the [itex]x-y[/itex] plane?
2) Do the magnitudes always cancel out for between [itex]\hat n[/itex] and 'dS'? I ask this because I think it is still quicker (at least in this problem) to just get the [itex]\hat n[/itex] as I did above, but I could just ignore the normalization constant, knowing that it will cancel out.
Many thanks for the help
Yes, they always cancel out. If your surface is ##S: \vec R = \vec R(s,t)## then your unit normal vector will be $$\hat n = \pm \frac {\vec R_s \times \vec R_t}{|\vec R_s \times \vec R_t|}$$ and your element of surface area is ##dS = |\vec R_s \times \vec R_t|ds dt##. So when you calculate
##d\vec S = \pm \hat n dS## the ## |\vec R_s \times \vec R_t|## terms cancel out. The choice of the ##\pm## is taken so that ##\pm \vec R_s \times \vec R_t## agrees with the given orientation.
LCKurtz said:
Yes, they always cancel out. If your surface is ##S: \vec R = \vec R(s,t)## then your normal vector will be $$\hat n = \pm \frac {\vec R_s \times \vec R_t}{|\vec R_s \times \vec R_t|}$$ and your element of surface area is ##dS = |\vec R_s \times \vec R_t|ds dt##. So when you calculate
Thank you very much for responding
→S=x^i+y^j+(1−x−y)^k​
The z-component does not look correct to me. You want the surface given by ##z=2-y##.
Yes, you are correct. I accidentally mixed up a similar question with this one when typing that. Then calculating [itex]\hat n dS[/itex] does yield a 'non-normalised' version of the normal vector which I calculated above.
Thanks
