Stuck on Physics Assignment: Find Force & Distance
The discussion revolves around a physics assignment involving a particle of mass m moving in a straight line under the influence of a force that opposes its motion and depends on its speed. The problem requires finding the force acting on the particle as a function of its speed v and determining the distance traveled by the particle over a specified time interval T.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the application of Newton's second law and the relationship between force, speed, and time. There are attempts to manipulate integrals and differentiate equations to express force in terms of speed. Questions arise about the validity of moving terms across integrals and how to express force in terms of different variables.
Several participants have provided insights and hints regarding the integration process and the relationship between variables. There is ongoing exploration of how to express force in terms of speed, with some participants suggesting methods to differentiate and rearrange equations. Multiple interpretations of the problem are being discussed, but no consensus has been reached on the final form of the equations.
Participants are working under the constraints of the homework assignment, which may limit the information available and the methods that can be used. The discussion includes questioning assumptions about the relationships between variables and the implications of the equations provided in the problem statement.
GFreeman64
Hello everyone,
This is my first time in Physics forums so forgive me if I stray from the convention for asking questions. Me and a friend are completely stumped on our first assignment for the year and we are not sure where else to turn!
A particle of mass m can move in a straight line. The only force acting on the particle opposes its motion, and depends only on its speed. The time T taken for the particle to come to rest after it is set into motion with speed u is given by the formula [itex]T=klog(1+au)[/itex] for all u, where k and a are positive constants. Find the force acting on the particle during the interval [itex]0\leq t\leq T[/itex] as a function of its speed v. Find also the distance the particle travels in time T.
Hint: Recall that the first fundamental theorem of calculus states that [itex]\frac{\mathrm{d} }{\mathrm{d} x} \int_{a}^{x}f(w)dw=f(x)[/itex].
[itex]T=klog(1+au)[/itex], [itex]\frac{\mathrm{d} }{\mathrm{d} x}, \int_{a}^{x}f(w)dw=f(x)[/itex]
[itex]F(v)=m\frac{\mathrm{d}v }{\mathrm{d} t}[/itex]
As far as I can see the best thing to do is take Newton's second law stated above, and separate the variables to give:
[itex]m\int \frac{dv}{F(v)}=\int_{0}^{T}dt[/itex]
Which would give simply T on the RHS, so substituting for T would give:
[itex]m\int \frac{dv}{F(v)}=klog(1+au)[/itex]
Now I am not sure how to proceed. I am tempted to try and take F(v) out of the integral to the other side of the equation, but I'm not sure whether this is allowed:
[itex]m\int \frac{dv}{klog(1+au)}=F(v)[/itex]
If so, then my answer would simply be [itex]\frac{mv}{klog(1+au)}=F(v)[/itex]. Any ideas as if this is correct?
For the second part I think I need to modify our starting point with Newton's second law to say:
[itex]mv\frac{\mathrm{d} v}{\mathrm{d} x}=F(v)[/itex]
But after that I am a bit lost. If I have the equation for F(v) perhaps I can separate variables again and then express v as dx/dt and integrate again. Unfortunately i cannot see far enough ahead to see how this would work.
Thanks everyone in advance for taking a look at this!
You are almost there. You cannot have a definite integral of the RHS, but an indefinite integral on the LHS. So the correct equation is:
[tex]m\int^{0}_{u} \frac{dv}{F(v)}=\int_{0}^{T}dt = klog(1+au)[/tex]
Suppose you know [itex]F(v)[/itex], how would you do the integral? You would have to taking anti-derivative of [itex]\frac{m}{F(v)}[/itex]. This should give you a hint of how it is related to the RHS. If still unsure, take derivative with respect to [itex]u[/itex] on both sides.
As for the second part, since [itex]T(u)[/itex] is the time it takes to stop the particle with velocity u, then at any intermediate time t when the particle is traveling with velocity [itex]v(t)[/itex], it would take [itex]T(v)[/itex] more time to stop it. Therefore, [itex]t + T(v)= T[/itex]. This allow you to invert and find [itex]v(t)[/itex], from which you can integrate to find [itex]x(t)[/itex].
Ah hah!
So if we were to differentiate both sides with respect to u, the RHS would become ka/(1+au). Then using the theorem given in the hint the LHS would become -1/F(u). So that gives us:
[itex]F(u)=-\frac{1+au}{ka}[/itex].
However the question asked for the force in terms of v, so how might I go about that from here?
Thanks very much for your help so far!
Can T=K log(1+au) be rearranged to give us u?
u=1/a * ((10^(T/K)) -1))
If that is substituted back into the equation for force...
F(T)=-(10^T/K) / Ka
Does this get us anywhere?
Let me give you a simpler example here. Suppose [itex]f(x)[/itex] satisfies [itex]\int_0^y f(x) dx = \frac{y^2}{2}[/itex]. I differentiate both side with respect to [itex]y[/itex] and get [itex]f(y) = y[/itex]. What is [itex]f(x)[/itex]?
Hmm, so in your example here, if f(y)=y then it would also be true that f(x)=x. Is then as simple as saying that if:
[itex]F(u)=-\frac{1+au}{ka}[/itex] then [itex]F(v)=-\frac{1+av}{ka}[/itex]?
If we substitute this expression for F(v) into the original integral it seems to almost work, apart from the fact that we still have a factor of m:
[itex]m\int_{u}^{0}\frac{dv}{F(v)}=kmlog(1+au)[/itex]
Thanks again.
If we were to say that:
[itex]F(v)=\frac{m(1+av)}{ka}[/itex]
Then the integration seems to work and is equal to [itex]klog(1+au)[/itex]. For now I'll assume this is correct.
For the second part I have taken the equation t+T(v)=T(u) to give:
[itex]t+klog(1+av)=klog(1+au)[/itex]
Rearranging this for v gives:
[itex]v=\frac{1+au}{a10^{t/k}}-\frac{1}{a}[/itex]
Integrating this between 0 and T gives:
[itex]x=-\frac{k(1+au)10^{-t/k}}{a}-\frac{t}{a}[/itex]
Which is showing a negative value for the position x. I think this is probably incorrect, but I am not sure where I have gone wrong...
