Stumped can someone derive a formula for this single variable problem?
The discussion revolves around deriving a formula to calculate a new number, X, that maintains the ratio of the 3-day average to the 10-day average after updating a series of numbers. The key equation established is that the ratio of the sums of the relevant averages must remain constant even as the oldest number is dropped and X is added. Participants suggest setting the two ratios equal to each other and solving for X. The challenge lies in implementing this formula in Excel, as it requires handling variables effectively. The conversation emphasizes the need for a clear algebraic approach to find the value of X.
AD1985
You have 10 days of numbers that are averaged together (10 day avg). The most recent 3 days of numbers also averaged (3 day avg). The 3 day average is divided by the 10 day average to arrive at (3d/10d)
The oldest number in the series is dropped off and a new one, X, is added. X is the newest number and thus a part of both the day and 3 day average. The (3d/10d) remains the same. What is X?
I need to write a formula for this in excel! That means every computation on one side of the = sign, and I'm not even sure if Excel can take variables. I think the trick is figuring out the forumla for the new 3d/10d, but not sure. Any ideas?
http://img169.imageshack.us/my.php?image=3d10davged2.png
Thanks
Mathematics news on Phys.org
Setting the two ratios (3day / 10day) equal, we get
<br /> \frac{sum(b8..b10)}{sum(b1..b10)} = \frac{sum(b9..b10) + x}{sum(b2..b10)+x}<br />
Solve that equation for x to get your answer.
Thank you! It's been a while since I've penciled down an algebra equation, let's see if this rusty old brain can get that X value now :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
