Suggestions/tutorial to build clock-like lazy susan?
  • Thread starter Thread starter ebsseattle
    Build
To build a turntable using a lazy susan for photography, a simple method involves attaching a large gear to the lazy susan and using a single nail as a catch for rotation. Accuracy within low tolerances is acceptable, allowing for manual adjustments using drawn radial lines instead of precise divisions. For more structured increments, standard dividing engine methods like a worm and wheel with an index plate can be employed. An index scale can be added to the turntable's rim using either a tape measure or printed segments for easy reference. Automation is not necessary, as the goal is to achieve roughly even increments for effective object rotation.
ebsseattle
I'd like to build a simple turntable using a lazy susan and a bunch of spokes (anywhere from 245-360) so that I can rotate the lazy susan one notch at a time and take a photo of an object sitting on tip of it. The goal is to hold a camera steady on a tripod and rotate the object.
Can anyone suggest materials to use to set this up without manually having to go in and split a circle in 250 parts and hand-drive 250 nails into the wheel?
Get a large gear with the right number of teeth and glue it to the lazy susan, then put just one bendy mail into the base plate as a catch.
Is it necessary that they are accurate within a low tolerance? What if you just drew out 360 radial lines in pencil and manually moved the base? If you were looking to animate it, it's not like a deviation of a 1/2 degree in one frame will be noticeable.
Stepper motor and a bit of DIY electronics is easiest way .
Otherwise :
(a) Use standard dividing engine methods - worm and wheel with index plate .
(b) Put an index scale on rim of turntable . Two methods:
Use a length of tape measure to make a loop and adjust diameter of turntable so that loop just fits over .
or
Print out a scale with suitable divisions on your printer (probably in sections) and fit as for tape measure loop . Alternatively fit as segments on the flat .
Yeah. Worm gear would work well. It can subdivide the increments of the larger gear into a fraction of a tooth.
Unless you say so, I don't think it needs to be automated.
Thanks for the suggestion. No, it doesn't need to be automated, and DaveC426913, it doesn't have to be mechanically precise. I just wanted something that has roughly even increments.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
