When Would Planets Go Dark if the Sun Went Out?
When the Sun goes dark, Earth-based observers will first see the Sun extinguish at 0:00, followed by a delay in the visibility of planets due to the time it takes for sunlight to travel. Mercury and Venus will reflect sunlight for a few seconds to a couple of minutes after the Sun goes dark, depending on their positions in their orbits. The outer planets, including Jupiter, Saturn, Neptune, and Pluto, will also experience a delay, which varies based on their distances from both the Sun and Earth. Calculating these delays requires using NASA's Horizons database to obtain the current positions of the planets and applying the speed of light to determine the time taken for sunlight to reach Earth.
  • Understanding of light speed (300,000 km/s)
  • Familiarity with celestial mechanics and planetary orbits
  • Knowledge of NASA's Horizons database for astronomical data
  • Basic programming skills for using Python libraries related to astronomy
  • Research how to use NASA's Horizons database to generate ephemeris data
  • Learn how to apply Pythagorean theorem to calculate distances in space
  • Explore Python libraries for astronomical calculations, such as Astropy
  • Study the effects of light travel time on astronomical observations
Astronomers, astrophysics students, educators, and anyone interested in understanding the dynamics of light travel in the solar system and its implications for observing celestial events.
mopc
TL;DR
If the Sunlight lets say would go off, exactly how long would astronomers on Earth still see sunlight reflected on the surface of Mercury, Venus, Mars, the asteroids, Jupiter Saturn, etc.?
I mean Sun goes dark at 0:00 from the point of view of Earth-based observers. At that exact moment, if they looked at Venus and Mercury, would they still see a few minutes of sunlight reflecting off their surfaces? And the outer planets Jupiter Saturn, Neptune, Pluto?
Or would we just see everything going dark at the same time?
Because if we see the Sun going dark at 0:00, tht means it went dark at 23:52'. Then Mercury and Venus must have gone dark a few minutes later, like 23h53 for Mercury and 23h55 for Venus , but thats in imaginary absoute time, we would see Venus going dark depending on how far Venus is from us + light speed, supposing the Solar System is in the arrangement of today, at what times would we see from Earth the surface of each planet going dark?
Astronomy news on Phys.org
You seem to understand how to do the calculation, so all you need is the current locations of the planets. This page discusses data sources, including NASA's Horizons database. I think you just want to set Ephemeris Type to Vector Table, Edit the Coordinate Center to be the sun (you can search for @sun - sorry PF user sun, I can't work out how not to ping you while typing that), Edit the date range, then generate the table for each Target Body. Read off the x,y,z values and apply Pythagoras to get distances, then divide by 300,000 km/s to get delays in seconds.
The first link discusses some python libraries that may make that easier if you know some programming.
We would see the Sun go out first, then the planets would go dark. This is because sunlight from the Sun travels a straight line to us and thus a shorter distance than the sunlight that ends up getting reflected from each planet to us. The time taken would be the sum of the distances from the Sun to a planet and then from the planet to Earth divided by the speed of light. For example, Mercury and Venus would taken anywhere from an extra few seconds to an extra minute or two depending on where they are in their orbits (rough guess, I haven't done the math). The planets outside of Earth's orbit would also show some variability based on our orbital positions.
  • · Replies 34 ·
  • · Replies 19 ·
