Sunspots visible for 2 Sept 2017
  • Topic: Stargazing
  • Thread starter davenn
13 replies · 3K views · last reply
A quick shot of the sun this morning
Nth lower left, East limb lower right
400mm telephoto = x2 teleconverter, 500th sec, f11
Photograph of the full Sun in white light against a black background, showing a few dark sunspot groups on the right side of the disc, with a small group near the upper left.
Very nice! I'm guessing that big sunspot is probably larger than the Earth?
davenn said:
Nth lower left
Nth = North?
davenn said:
400mm telephoto, 500th sec, f11
What kind of filter do you have on your camera?
I haven't seen any specific comments but would also guess about the same size to a bit bigger
Drakkith said:
Nth = North?
yup ... my usual abbreviation
nth, sth ... :smile:
this ...
Silver-and-black telephoto zoom lens lying on a patterned cloth, its front element covered by a full-aperture solar filter held with tape.
http://www.telescope.com/Accessorie...lescope-Solar-Filters/pc/-1/c/3/sc/48/e/4.uts
That's the 100 - 400 mm lens with a 2 x adaptor on it
A labeled image from about the same time that shows the scale of Earth and Jupiter.
SDO HMI full-disk image of the Sun dated 2-Sep-2017, with numbered sunspot groups 2672, 2673, 2674 and 2675 labelled, and a scale comparison with Earth and Jupiter at lower right.
The large group continues across the sun
there has been new spots appear to the east of this long string of spots plus a new set coming around the east limb
4th Sept 2017
rotation is from lower right to upper left ( as seen through my camera)
You can also see the smaller single spot up from the large spot chain has also evolved into a much more complex structure over the last 24 - 48 hrs
you can view this animation ( Note, the image source has corrected image orientation) ...
http://www.spaceweather.com/images2...anim.gif?PHPSESSID=0u7620108s1at1gnt6ilu816i5
There have so far been 3 M class flares recorded. Not sure which group they originated in ?
White-light photograph of the full solar disk with several dark sunspot groups; a long chain of spots sits right of centre and a smaller, irregular spot cluster lies above it.
Dave
The Sun
4th Sept 2017
rotation is from upper right to lower left ( as seen through my camera)
The upper group continues to grow in size and complexity and it is also becoming more active
Full-disc photograph of the Sun in orange-tan tones showing three dark sunspot groups, two smaller clusters on the left and right and a larger dark spot near the centre.
Quite a number of solar flares have occurred over the last 24 - 36 hrs. Both spot numbers and flare count
is the highest it's been for many month
Approximate Flare Maximum: 04-09-2017 0549 UT at Flux M 1.3
Approximate Flare Maximum: 04-09-2017 1531 UT at Flux M 1.5
Approximate Flare Maximum: 04-09-2017 1822 UT at Flux M 1.0
Approximate Flare Maximum: 04-09-2017 2033 UT at Flux M 5.5
Approximate Flare Maximum: 05-09-2017 0108 UT at Flux M 4.2
Approximate Flare Maximum: 05-09-2017 0351 UT at Flux M 1.0
Approximate Flare Maximum: 05-09-2017 0453 UT at Flux M 3.2
Approximate Flare Maximum: 05-09-2017 0640 UT at Flux M 3.8cheers
Dave
The Sun today -- 6 Sept 2017
2 large spot groups continue to dominate the solar disk
Full disk of the Sun in white light showing several dark sunspots, mostly in two clusters: a larger group at upper left and a smaller group near the centre-left.
The Sun has been quite active today- 2 X class flares since 0900UT.
GOES X-ray flux plot for 6 September 2017 from 0700 to 1300 UTC, log scale in watts per square metre, with red and blue curves for the 1.0-8.0 and 0.5-4.0 Angstrom bands showing two large flare peaks near 0920 and 1200 UTC.
My reaction when I first saw this is unprintable here!
Only one X class is listed, an X9.3 which is huge !
that other one after 0900 UT was a M7.7Dave
The plot indicates that the 0900UT event was in the X1 - X2 range.
it's been officially listed as a M7.7 :smile:
Excellent photography in this thread! Regarding the two dominant spot groups (AR2674 and 2673), here is an interesting short video:
Also, regarding the monster X-class flares (just today 6 Sept), here is another one:
Not trying to be contrary, but these 2 lines are from the Space Weather Prediction Center's Edited Events list for today- they show the events as x2.2 and X9.3
Code:
#Event    Begin    Max       End  Obs  Q  Type  Loc/Frq   Particulars       Reg#
7250       0857   0910      0917  G13  5   XRA  1-8A      X2.2    1.3E-01   2673
7340 +     1153   1202      1210  G15  5   XRA  1-8A      X9.3    5.7E-01   2673
The full file is available at - Edited Events for 2017 Sep 06
And the videos from NASA initially mentioned X2.2 and X9.3 ... but that may have changed later (?) ...
Also, here comes the CME ... (announced just over an hour ago):
"Latest news
Coronagraph image of the Sun showing a dark occulting disc with a white circle outline at centre and a bright, hot-orange plasma eruption extending outward on the right side.
Wednesday, 6 September 2017 - 21:09 UTC
X9.3 earth-directed coronal mass ejection
More news"
