Superposition - broadcast antenna question
1 reply · 5K views
rpa3010
The broadcast antenna of an Am radio station is located at the edge of town. The station owners would like to beam all of the energy into town and none into the countryside, but a single antenna radiates energy equally in all directions. There are two antennas separated by a distance L. Both antennas broadcast a signal at wavelength lambda, but antenna 2 can delay its broadcast relative to antenna 1 by a time interval delta t in order to create a phase difference delta phi_0 between the sources. Your task is to find values of L and delta t such that the waves interfere constructively on the town side and destructively on the country side.
We are given this additional information:
Let antenna 1 be at x = 0. The wave that travels to the right is asin[2pi(x/lambda - t/T)]. The wave that travels to the left is asin[2pi(-x/lambda - t/T)]. Antenna 2 is at x = L. It broadcasts waves asin[2pi((x-L)/Lambda - t/T) + phi_20] to the right and asin[2pi(-(x-L)/lambda - t/T) + phi_20] to the left.
a) What is the smallest value of L for which you can create perfect constructive interference on the town side and perfect destructive interference on the country side? the answer should be a multiple or fraction of the wavelength lambda.
b) What phase constant phi_20 of antenna 2 is needed?
a) The smallest value of L for which we can create perfect constructive interference on the town side and perfect destructive interference on the country side is one-half of the wavelength (λ/2).b) The phase constant phi_20 of antenna 2 needed is π.
