SVD and image compression for Matlab
2 replies · 4K views · last reply
matqkks
Are there any resources which use Matlab to image compress a colour image using SVD? I can only find information where I need to convert to gray scale first.
Here's what MATLAB says about the conversion:
https://www.mathworks.com/help/matlab/math/image-compression-with-low-rank-svd.html
In their example, they also do the image to grayscale conversion via rgb2gray() after reading in the image. I'm thinking that has to be done because the SVD algorithm won't work with colors which are represented as triplets as in (R,G,B) formulation whereas a grayscale is a single value for each pixel.
According the MATLAB:
the rgb2gray(RGB) converts the truecolor image RGB to the grayscale image I. The rgb2gray function converts RGB images to grayscale by eliminating the hue and saturation information while retaining the luminance. If you have Parallel Computing Toolbox™ installed, rgb2gray can perform this conversion on a GPU.
If you have Image Processing software that can save the colors indiviually to separate files that could be a solution. Merging the compressed color layers back to something usable may not be possible though.
