Symbolic intergration in Matlab using INT command?
  • Context: MATLAB
  • Thread starter Thread starter ACT
    Intergration Matlab
The discussion revolves around the use of the "INT" command for symbolic integration in Matlab, exploring when and how to apply it effectively. Participants express confusion regarding its usage and provide examples and suggestions.
  • Exploratory, Technical explanation, Homework-related
  • One participant expresses confusion about when to use the "INT" command for symbolic integration in Matlab.
  • Another participant suggests that the transition to symbolic multiplication might be relevant to the use of the "INT" command, though this point is unclear.
  • A later reply provides a specific format for using the "INT" command, including an example of defining a function and performing an integral from 1 to 100.
Participants generally express confusion about the topic, and there is no consensus on the correct approach or understanding of the "INT" command.
Some assumptions about the understanding of symbolic operations in Matlab may be missing, and the clarity of the proposed method may depend on the participants' familiarity with Matlab syntax.
ACT
Symbolic intergration in Matlab using "INT" command?
Hello,
I am a bit confused a to when should we use the Symbolic intergration using "INT" command in Matlab ?
Thanks
hii
also and me,
But ,I think at the time when change to symbolic multiplication (*)...
with my best wishes...!
cotton candy said:
hii
also and me,
sorry but i don't understand ur reply!
the format in MATLAB is
int( function, 'variable' ).
For example, to calculate the integral from 1 to 100, the object function is x^2 + \sin (x), you should do following:
1. define the function as
f = 'x ^ 2 + sin(x)';
2. integral
int( f, 'x', 1, 100 )
  • · Replies 32 ·
