System of Equations: Unique Solution Conditions
The discussion revolves around determining the conditions under which a given system of equations will have a unique solution. The equations involve a parameter 'a' and are presented in both standard and matrix forms.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the concept of matrix inverses and the conditions necessary for the system to have a unique solution. There is an attempt to apply Gaussian elimination and questions arise regarding the relevance of the right-hand side of the equations in finding the inverse.
The discussion is ongoing, with some participants providing guidance on the use of matrix forms and Gaussian elimination. There is a question about the necessity of the right-hand side of the equations when considering the inverse, which has been affirmed by another participant.
The parameter 'a' introduces variability in the conditions for a unique solution, and the implications of this parameter are under consideration. The original poster expresses uncertainty about how to begin the problem-solving process.
emilieloops
Under what condition will the following system have a unique solution?
x -y +2z = 1
ax -ay +4z = 2a
x +y +az = 4
Note: a is a parameter.
I know I'm supposed to solve by turning this into the identity matrix by I really have no idea where to start. Hellp would be much appreciated.
Rewrite the equation in matrix form:
1 -1 2 x 1
a -a 4 * y = 2a
1 1 a z 4
This system is has a unique solution if the matrix on the LHS has an inverse.
From your (3) it seems that you are to use Gaussian elimination:
http://en.wikipedia.org/wiki/Gaussian_elimination
Depending on how you set this up it can provide the inverse matrix and the solution.
1 -1 2 x 1
a -a 4 * y = 2a
1 1 a z 4
Can I ignore the right side of all the equations in order to find the inverse?
  • · Replies 17 ·
  • · Replies 69 ·
11K
