System of Simultaneous Congruences
  • Thread starter Thread starter Korg
    System
11 replies · 6K views · last reply
Korg
Solve the following system of simulataneous congruences:
2X+3Y = 2(mod 5)
X+2Y = 3 (mod 5)
X+2Y = 3 (mod 7)
4X+3Y = 4 (mod 7)
I know how to solve a similar problem if there was just one variable, using the Chinese remainder theorem but I'm not quite sure how to adapt it here. I know the CRT is applicable since 5 and 7 are coprime.
I started trying to solve it by using the two X+2Y congruences and got that X+2Y = 3 (mod 35) . but I'm not sure if this even helps to solve the whole system.
Can anyone help at all?
I think, you can solve the first 2 equations, which gives
X=0 (mod 5)
Y=4 (mod 5)
and then the 3rd and 4th.. which gives
X=4 (mod 7)
Y=3 (mod 7)
And, then solve X=0(mod 5) and X=4(mod 7), which would give X=25 (mod 35)
similarly for Y, you should get Y=24 (mod 35)
By the way, are you studying at Warwick university?
Thanks a lot, i get it now. I just wasnt sure how to handle it with 2 variables and then realized you can just treat it as a normal simultaneous equation when you're working with the same modulo.
And yes i do, you've found me out haha
lol! haha..
Im studying at Warwick too!
Just let me know if my answer is right or not, after u solve it.. coz, I'm not sure if I've made any careless mistakes in between..
hey I got same answer too, problem I am having is solving the second set of equations
X+2Y = 3 (mod 7)
4X+3Y = 4 (mod 7)
I know the answer I want but the matrix I make to get this answer gives me the wrong solutions, does anyone have any help to do this? I can do the rest of the problem easily and get the same answer as you guys I just can't see where I am going wrong on this part
I think, you can multiply equation 1 by 3 and then subtract it from 2, which will give you a value for Y, and then substitute in any of the equations to get X
ah yeah thanks that does work but i find the matrix method to be better as technically multiplying the first equation by 4 should give me 4X + 8Y = 12mod28
as if a = bmod(m) then na = nbmod(nm) which whilst your way does give the correct answer I am not sure its technically right as I did do that in the first place but then wondered about if it was actually true
i used a matrix method which worked for the first set but on this one my matrix just doesn't work, i need the det to be 1 diffrent than it is but maybe I can skip that and say by the method used in step one
hey
how do we use matrices to solve these? Ax=b?
Well, what I did was:
3X+6Y=9+21m
4X+3Y=4+7n
Adding them gives:
7X+9Y=13+7(3m+n)
9Y=13+7(3m+n-X)
9Y= 13 (mod 7)
9Y= 6 (mod 7)
So, Y=3 (mod 7)
Please let me know if the above is right or wrong, and also if the matrix method is more sophisticated...thnx
yeah your way works, you wouldn't need 9Y either you could just put 2Y as 9 = 2mod7
the matrix way is [a b
~~~~~~~~~~~c d] [X,Y]^T = [ e f] ^T (sorry for the ~ had to make the matrix line up)
where aX + bY = emodn
cX + dY = fmodn
then you just multiply the left hand sade with the left inverse of the 2x2 matrix to find X, Y
worked for me in the first case fine but something went wrong in the second case, I think it is more sophisticated and definitely helps when you have more than 2 equations or 2 variables however I seem to have made a mistake in my second matrix for the mod7 part but I can't figure out where, works perfectly and easily for the first part
for the 2nd part (using matrices)
(X, Y) = (-1/5, 8/5)
So, 5X=-1 mod 7
5X=6 mod 7, hence X=4 mod 7
Similarly for Y
5Y=8 mod 7=1 mod 7
So, Y=3 mod 7
So, it does work and is definitely more sophisticated! :)
ah yeah thanks i had tried to convert the determinant into mod7 instead, easier to not do that it turns out, cheers :)
