Temperature Below 0 at Depth: Find x_min
  • Thread starter Thread starter bobred
    Depth Temperature
6 replies · 2K views · last reply
bobred
Determine at what depth below the surface the temperature never falls
below zero.
[tex]\theta(x)=\bar{\theta}+\theta_0\cos\left(\omega t-\sqrt{\dfrac{\omega}{2D}}x\right)\exp\left(-\sqrt{\dfrac{\omega}{2D}}x\right)[/tex]
where the average is [itex]\bar{\theta}=2.5[/itex] and amplitude [itex]\theta_0=7.5[/itex]
At a depth x the temperature will be reduced by a factor
[tex]\exp\left(-\sqrt{\dfrac{\omega}{2D}}x\right)[/tex]
so for some ratio R
[tex]R=\exp\left(-\sqrt{\dfrac{\omega}{2D}}x_{min}\right)[/tex]
I'm having trouble figuring out what R is so that I can find [itex]x_{min}[/itex].
Any suggestions?
Is theta the temperature? If so, you have something that looks like
[tex] \text{Temperature} = \text{const} + A \cos (\text{something}) \times e^\text{something else}[/tex]
You never want the temperature to fall below zero. The lowest value of the cosine function is -1. So ask when
[tex] 0 \leq \text{const} - A \times e^\text{something else}[/tex]
Hi
Theta is temperature. The temperature ranges from +10 to -5.
bobred said:
Hi
Thanks for clarifying. At the surface (x=0), the temperature is in that range. The exponential factor in the second term lowers the "swing" in temperature. Now you need to solve for the depth at which this swing is low enough so that the temperature is never negative. Have a look at the last equation in my earlier post.
Confusing myself, here is an example I have been looking at
First, the equation in the OP isn't quite right. It should be ##\theta(x, t) = ...##, as shown in the later post. Pick some depth x. What is the minimum temperature that it can be at that depth?
Oops just noticed, the cos should include [itex]+\phi[/itex]
