Can anyone help with strange deflection in ANSYS 15 tensile test simulation?
The forum discussion addresses a tensile test simulation issue in ANSYS 15, specifically using the ACP PrePost and Static Structural modules. The user is modeling a dumbbell-shaped specimen made of 6 laminas of E FiberGlass oriented at +/-45°. The problem involves unexpected deflection in the simulation results, which may stem from boundary conditions or laminate configuration. A solution is provided, recommending the application of symmetry boundary conditions, constraining the specimen's end in all directions, and restricting deformations to in-plane only by fixing displacement in the Z direction.
  • Understanding of ANSYS 15 software and its modules, specifically ACP PrePost and Static Structural.
  • Knowledge of composite materials, particularly E FiberGlass laminate configurations.
  • Familiarity with boundary conditions in finite element analysis.
  • Basic principles of tensile testing and specimen geometry.
  • Research how to apply symmetry boundary conditions in ANSYS 15.
  • Learn about constraining boundary conditions for composite materials in finite element analysis.
  • Explore the effects of laminate orientation on tensile test results in ANSYS simulations.
  • Investigate methods to restrict deformations in ANSYS to control lateral deflection.
This discussion is beneficial for engineers, simulation specialists, and researchers involved in composite material testing and finite element analysis using ANSYS software.
Rawllet
TL;DR
Tensile test, using ACP Pre and Static Structural modules, of a fiber glass laminate with 6 layers orientated +/-45°.
Hello everyone!
I am trying to modelate a tensile test of dumbbell-shaped specimen under ACP PrePost and Static Structural modules. The laminate I am configuring consists of 6 laminas of E FiberGlass orientated +/-45°. For simplicity I am working with 1/4 of the geometry and the boundary conditions are 2 displacements. One that let's movement only in X axis and the other only let's movement in Y and Z axis.
My problem is a strange deflection that is shown in the solutions spot and I do not know what could be the reason of it. I don't know if is because of the boundary conditions or maybe a bad laminate configuration.
I wii be very thankful for any help. I attached a few photos that could help in the understanding of the problem.
Thank you in advance.
Apply symmetry boundary condition to cut edges. Constrain the end of the specimen in all directions and prescribe axial displacement value. To avoid lateral deflection you can restrict deformations to in-plane only using boundary condition applied to the whole surface of the specimen with fixed displacement in Z direction.
  • · Replies 23 ·
37K
